A/C question - Ford Truck Enthusiasts Forums
A/C question
Old 07-01-2014, 11:28 AM
lowrider50 lowrider50 is offline
lowrider50 is starting off with a positive reputation.
A/C question
I'm having a problem with the A/C in my 2005. It started blowing warm air in normal mode. If I switch to recycled air it blows cold air. I found the compressor runs in recycle but turns off in the normal mode. hoping somebody had this problem before or has some idea why .
Old 07-03-2014, 02:53 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Probably will need to replace the head unit (the HVAC control unit in the dash).
Old 07-09-2014, 06:26 AM
RangerFL1 RangerFL1 is offline
RangerFL1 is starting off with a positive reputation.
Wire needs to be check, There might be some loose connection
Old 07-09-2014, 08:47 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
There's no wire to check.
If the compressor works in the normal climate control modes but does not only in the MAX A/C mode, the only thing it can be is either the switch (if a manual control) or the EATC (if equipped) as 1saxman alluded to.
A/C Blower Issues SmackDaddy Excursion - King of SUVs 4 11-23-2016 12:10 PM
A/C Recycling problem WarX Excursion - King of SUVs 0 08-04-2014 08:19 AM
a/c Stuck in defrost mode murrayvlow 1997 - 2003 F150 7 01-28-2011 08:36 AM
high speed whistle ro.co3 2004 - 2008 F150 45 05-12-2009 09:24 PM
Expedition Rear AC not working chaneyb Cooling, Heating, Ventilation & A/C 1 06-21-2005 04:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
