A/C question - Ford Truck Enthusiasts Forums
A/C question
Old 07-01-2014, 10:28 AM
lowrider50 lowrider50 is offline
lowrider50 is starting off with a positive reputation.
A/C question
I'm having a problem with the A/C in my 2005. It started blowing warm air in normal mode. If I switch to recycled air it blows cold air. I found the compressor runs in recycle but turns off in the normal mode. hoping somebody had this problem before or has some idea why .
Old 07-03-2014, 01:53 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Probably will need to replace the head unit (the HVAC control unit in the dash).
Old 07-09-2014, 05:26 AM
RangerFL1 RangerFL1 is offline
RangerFL1 is starting off with a positive reputation.
Wire needs to be check, There might be some loose connection
Old 07-09-2014, 07:47 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
There's no wire to check.
If the compressor works in the normal climate control modes but does not only in the MAX A/C mode, the only thing it can be is either the switch (if a manual control) or the EATC (if equipped) as 1saxman alluded to.
A/C Blower Issues SmackDaddy Excursion - King of SUVs 4 11-23-2016 11:10 AM
A/c Issue, 2010 Explorer, EB muneeb Explorer, Sport Trac, Mountaineer & Aviator 1 04-25-2016 07:45 AM
Rear A/C Blowing Hot Air Schlump Cooling, Heating, Ventilation & A/C 11 07-20-2015 03:25 PM
A/C Recycling problem WarX Excursion - King of SUVs 0 08-04-2014 07:19 AM
05 Expedition blows hot air through defrost vents when set in max a/c mode jbedsole23 1997-2006 Expedition & Navigator 4 03-11-2014 06:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
