Gear shift indicator
Old 07-01-2014, 12:17 AM
1L243's Avatar
1L243
1L243 is offline
Yesterday I was driving my truck and noticed that my gear shift indicator in the dash has dropped between gears. It's a early 99. Anybody else had this happen? Is this usually a problem in the dash or in the linkage to the transmission?
Old 07-01-2014, 01:05 AM
whitetmw's Avatar
whitetmw
whitetmw is offline
It's loose under the dash close to the steering column. The video shows it (you won't have to do the entire project unless its broken)
Old 07-01-2014, 02:04 AM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
I didn't watch the video, but there are 2 torx screws at the base of the column that tend to loosen up if your shifter is sloppy most likely it is here.
If the shifter is tight then it could just be the thumbwheel needing adjusted, this is behind the fuse panel cover on the bottom of the column.
Julie's77
08-27-2018 07:17 AM
greenf150flareside
01-27-2018 05:38 PM
PapaMatt
03-19-2015 07:17 PM
blueoval1988
05-01-2010 08:56 AM
Phinxter
08-11-2004 09:35 PM
Quick Reply: Gear shift indicator
