1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
power point and cig lighter not working
Old 06-30-2014, 10:08 PM
kengarchow's Avatar
kengarchow
kengarchow is offline
don't know if i messed this up but on my 06 SD i changed the face of my cluster and after putting all back together i noticed today the cig lighter and power point are dead
both and both on sep fuse and they are good
is there a master fuse of them? or other ideas
i did have the whole dash panel out and unplugged but its back together
thanks
Old 07-01-2014, 01:49 AM
kengarchow's Avatar
kengarchow
common ground?
i saw on the crew cabs there may be a common ground between the power points and cig lighter
anyone know where this is in a ext cab
thanks
Old 07-01-2014, 03:34 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
You just un-plugged the cluster and plugged it back in?
If that is the case both of those two circuits are on the
Battery Saver Relay. That is controlled by the cluster.
So have a look at the plugs that go into the cluster.
Make sure all the pins are seated and not bent.
Post back and let me know. I have the books here and
will do some digging if needed.
Sean
Old 07-01-2014, 07:43 AM
kengarchow's Avatar
kengarchow
wow thats interesting
thanks for the tip, what happened in more detail is that i bought a harley cluster that had the chrome gauge face plate. i put that in my truck and noticed that about 1/2 of the dash lights in it didn't work, so took it back out and put my original in with the face off the new one.
now have all dash lights but lost the power point and cig lighter (have apple phone and they won't go all day with out charge)
ill pull dash apart again and check cluster pins thanks for the tip
may i ask are there other items on the power saver relay that would also not be working to help me diagnose the problem?
thanks
Old 07-01-2014, 12:01 PM
kengarchow's Avatar
kengarchow
OK GOT THIS ONE FIXED
ahh nothing was wrong with truck, it was my phone charger that didn't work
tried it in another car and it didn't light
got a second charger put it in truck and walla worked
sorry about the mix up
now to next issue……...
Old 07-01-2014, 12:42 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Good to hear you got it working.
To answer the question.
The windows,radio and inside lights in you leave the door open.
Sean
mrcman58
01-13-2017 01:43 PM
2003Navi
1997-2006 Expedition & Navigator
07-02-2013 08:03 PM
guikas
08-22-2011 10:34 AM
Littlejoe
03-06-2009 09:53 AM
BushWacker2
Electrical Systems/Wiring
06-22-2003 10:06 AM
Quick Reply: power point and cig lighter not working
