Sponsored by: Halo Lifts
Any updates? Release date?
Old 07-14-2014, 08:39 AM
Doc's Avatar
Doc
Doc is offline
So what's the latest? Is Ford any closer to a release date? What's the projected price range for the trucks? Yes, I realize this has been beaten to death all over the internet, but it's almost August, and inquiring minds want to know.
Old 07-17-2014, 05:36 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,221 Likes on 803 Posts
All I'm hearing is late 2014. My dealer said the other day around December they should be rolling in.
Old 07-17-2014, 08:18 AM
raven3's Avatar
raven3
raven3 is offline
There is a link on the Ford site that indicates aluminum metal forming is causing a delay in production start date.
Having been a metalist for 40 years, can appreciate the difficulity in forming the truck body parts from aluminum and more difficult than forming steel parts.
If high strength heat treated aluminum is cold formed, the material may crack.
High strength steel does not have as much chance of cracking during the cold forming operation.
Usually the lower strength un heat treated aluminum alloy is formed, then the formed material is heat treated to proper high strength properties.
When metal is permanently deformed to a shape there is a so called spring back from the initial amount of forming deformation back to the final shape. This the elastic portion of the total deformation.
When heating the final shape to heat treat thermal gradients develop in the materials.
These thermal gradients create a state of stress in the metal and if sufficiently large enough, the metal will permanenly deform, again. The final heat treated shape is then not the desired shape. The level of thermal gradient is dependent on the geometry of the part. The higher the thermal gradient, the higher th stress.
From the Ford site showing the shape of the aluminum body, it appears there are some rather complex formed shapes.
Old 07-18-2014, 02:02 AM
CGiron's Avatar
CGiron
CGiron is offline
Still 16 of July for orders
F150
Dearborn Plant
Orderbook opens 16 Jul 2014
SOP 20 Oct 2014
according to
Ford Trucks: Build-out and Start-Up Dates
and several others.
Old 07-20-2014, 12:49 AM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
I won`t be ordering but can`t wait to test drive.....I`ll hit all my local dealers up for a free spin
Old 07-20-2014, 01:16 AM
CGiron's Avatar
CGiron
CGiron is offline
I mailed Mike Levine at Ford and got the answer that SOON the orderbooks will be open. The information from Ford Trucks: Build-out and Start-Up Dates
is not really correct. SOON.
I think that the information about hp and mpg will be released at that time.
Old 07-20-2014, 02:14 AM
IJAZ FAHTED's Avatar
IJAZ FAHTED
IJAZ FAHTED is offline
Can't weld aluminum. The body panels are GLUED or riveted together. I don't know if I want to own a pickup that's "GLUED" together.
( I think you already knew that but you purposely failed to mention that )
Old 07-20-2014, 08:42 AM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
Glue joints are as strong, if not stronger that spot welds. Its been proven to be strong enough for semi trucks, so there is no reason it cant be used on a pick up truck. Did you make an account just to bash the new f-150 that hasn't even been released yet?
Old 07-21-2014, 02:48 PM
CGiron's Avatar
CGiron
CGiron is offline
Now Mike Levine is twittering that "There's 2015 F-150 news coming this week."
He knows
Old 07-23-2014, 09:16 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
Just interviewed for a job that may include a company truck. Pretty sure that company buys fords. Wonder if they'd buy me a 2015 Lariat EcoBoost? I guess we'll see. . . . .
Who's got guesses for when the order book will open and when they'll show up on Canadian dealer lots?
Old 07-24-2014, 06:22 AM
redford's Avatar
redford
redford is online now
Received 1,564 Likes on 912 Posts
Good luck on that!
Old 07-24-2014, 08:07 AM
Rob.D's Avatar
Rob.D
Rob.D is offline
I also drive a Ford company truck. Currently a 2010 F-150 supercab with the 4.8v. I was due for a new truck last winter due to mileage. But have managed to hold the company off on replacement until the 2015's come out. With they would hurry up. Currently at 172,000 on the 2010.
underthebridgejim
05-10-2017 08:34 PM
reamer
04-22-2012 11:47 AM
karljay
Garage & Workshop
05-04-2005 10:00 PM
clftn60
03-23-2005 11:16 PM
darkman
Garage & Workshop
03-09-2004 06:16 AM
Quick Reply: Any updates? Release date?
