Real world MPG on your v10 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 09:53 PM
wendal wendal is offline
wendal is starting off with a positive reputation.
I have been told that the v10 is hard on gas. So what are you guys getting for mpg?
I have herd the 6.0 chevy motor is not good on gas either. My old 351 was not that great on gas.
thanks again
Old 06-30-2014, 10:11 PM
MitchPeters MitchPeters is offline
MitchPeters is gaining momentum as a positive member of FTE.
12mpg when I'm easy on it. 7-9 towing 7k to 15k.
Old 06-30-2014, 10:32 PM
fordmerc's Avatar
fordmerc fordmerc is offline
fordmerc is starting off with a positive reputation.
I'm at around 14 empty and 8.5-9 towing our 7K loaded TT.
Old 06-30-2014, 10:46 PM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
Mixed driving in the 10-12 and around town 9mpg. 13.5-14 on a camping trip with this:
Old 07-01-2014, 07:09 AM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
thanks again
My real world mileage for my 2000 V10 F350 CCLB 4.30 gears and a 8.5 ft utility box weighing 9600 every day was 10 to 11 mixed driving doing service calls and going to constution sites, sometimes lower if I was pulling a trailer, I had a electric & refrigeration business. In the winter it was less because it idled more so I could keep warm.
Denny
Old 07-01-2014, 08:19 AM
cornwelltoolman's Avatar
cornwelltoolman cornwelltoolman is offline
cornwelltoolman is starting off with a positive reputation.
I have a 2003 v10 f350 I have pulled a 13,000lb trailer every day and avarage 9 over
the last 190,000 miles
Old 07-01-2014, 09:34 AM
toddb1 toddb1 is offline
toddb1 is starting off with a positive reputation.
I added a procharger to my 2v, I had a not so good first venture so my fill up strategy went into the crapper. The last leg home pulling the toy hauler in the hills generally took under 1/2 tank with an average of about 6mpg. With the supercharger not boosting I burned just over a 1/4 tank. I was able to use OD and hold 3rd on the smaller hills.
Old 07-01-2014, 12:02 PM
I had a 04 cc 4x4 with a 5.4 and it only got 14mpg no towning. If my v10 can get that not towing anything I would be happy.
My chevy with 350 might only get 15 now.
Old 07-01-2014, 12:31 PM
redbandit98 redbandit98 is offline
redbandit98 is starting off with a positive reputation.
mines an 08. It seems to like gas more than others for some reason. Bone stock crew cab 4x4, 4.10 gears. All city driving = about 7-8 mpg. highway driving, 10-11mpg. I have almost hit 12 one time on a road trip. Needless to say anything over about 200 miles its actually cheaper for me to rent a car if Im just needing to get somewhere and not pull/carry anything. I'm not in a big city so rental cars are cheap to rent.
Old 07-01-2014, 06:48 PM
kas83 kas83 is offline
kas83 is starting off with a positive reputation.
7.5 mpg hauling 7-11k lbs the last few days. Just over 11 empty lately. Down from 9 loaded n 13 empty when I first got it. Truck doesn't seem to have the power it use to and has an odd stumble/misfire as well. Still troubleshooting tho.
Cruise set at 57 mph when I went to pick up my topper netted me 17.1 mpg on a 270 mile round trip. 16.8 on 320 mile round trip similar conditions a month after.
Old 07-01-2014, 09:16 PM
gfl gfl is offline
gfl is starting off with a positive reputation.
I'm not sure there is abig truck that does much better, they all like gas. I got 14 and change last i checked mostly freeway
Old 07-02-2014, 01:09 AM
tims01's Avatar
tims01 tims01 is offline
tims01 has a very good reputation on FTE.tims01 has a very good reputation on FTE.tims01 has a very good reputation on FTE.
what is milage .. i get about 3 gallons per mile lol
Old 07-02-2014, 06:51 AM
Army RET's Avatar
Army RET Army RET is online now
Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.
Just yesterday I delivered my HiLo camper (4K dry pounds) to my daughter, 160 miles away.
As I've perceived a slight occasional misfire (no codes) I decided to switch over to 93 octane, just to see if it'd help (it didn't). Pulling the trailer 160 miles (10 miles back roads, then equally spilt between 4 lane and interstate) at 5 mph below the limits then heading back home empty, running at the speed limit. At 250 miles I again gassed up. SURPRISE: I got 14 mpg on that trip.
Normally I run 87 octane around town, driving like your grandpa, and get 12 mpg.
In you're not aware - there is a web site to track your mileage, https://www.fuelly.com/dashboard where you can search what drivers are getting.
NOTE: VERY LATE EDIT BUT I JUST REMEMBERED ... I DID MAKE ONE OTHER CHANGE JUST BEFORE THIS ROAD TRIP. I REPLACED THE AIR FILTER. IT HAD A K&N (AND APPEARED CLEAN) BUT I WANTED TO RETURN CLOSER TO ORIGINAL. CLOSEST I COULD FIND AT O'REILLY WAS A WIX ($20).
Old 07-02-2014, 09:35 AM
Thanks for the web site.
Old 07-02-2014, 09:42 PM
katoranger katoranger is offline
katoranger is starting off with a positive reputation.
I get 12mpg consistently. Best has been 13.5. I am driving a 15 passenger van lightly loaded and usually towing a 16 foot equipment trailer. I have not done any tune up work, but just developed a miss.
Does the 3V 5.4 gets better mpg then the 2V 5.4? jac08f250 1999 to 2016 Super Duty 20 08-08-2016 08:56 PM
1978 F250 mpg?? FordyFordyFordy 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-05-2015 12:38 AM
Do the triton v10s suck gas? Drewster2016 1999 to 2016 Super Duty 84 05-29-2014 03:41 PM
Manuel verus Automatic donovan Modular V10 (6.8l) 2 05-26-2011 05:10 PM
Gas Mileage V10? FordtruckBoy13 Modular V10 (6.8l) 71 10-27-2006 01:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
