Real world MPG on your v10
#121
What I need is a way to take it off and put back on that is much easier. It's suffered much scratching and corner damage from being placed on the ground. Still looks good tho and is great to have covered/locked storage.
#122
#124
#126
#127
That's nothing short of amazing mileage. Is that hand calculated or from the Lie-O-Meter in the overhead?
What does that 35.5' TT weigh? Our 41' TT tips the scales at 11,000lbs.
Is that unleaded regular mixed with corn liquor? Nearly all of ours down here is and it hurts the mileage some.
What tuner and tunes are you running? We use 5Stars Custom Performance tunes both 87 and 89 Octane for all of our towing.
Is the terrain mostly flat where you are seeing that mileage? Here in the Eastern US I can't go very far without climbing some Interstate Highway grades (unless I head due South!).
We are seeing between 8 and 9.25 MPG towing our TT with our V-10 EX running a 4" lift with 35" and 4.88 gears (effective ratio of 4.39) using the above mentioned custom tunes and Banks headers and stock exhaust. Unloaded I get 13-ish highway MPG.
#128
Tank to tank on the lie meter. TT weighs 9000 lbs. Not sure what its mixed with. Its a procomp tuner, I run it on the 92 octane tune!!! Somewhat flat here in southern Alberta, British Columbia and Montana about half hour to an hour out. 3.73 diff's help!!! V10 is an awesome engine for torque pulling power. Anything better than my 01 F250 with the 5.4 at 13 mpg!!!
#129
I would suggest that you do some hand calculations to see what your actual MPGs are, Between the slightly taller tires and the tunes the overhead may be a little off. All of my numbers are hand calculated.
The pulling difference between my factory 3.73 gears and the 4.88s is huge, with the stock gears and a 9,500lb toyhauler behind we were getting 6 to 7.5 MPG on the relatively flat (some rolling hills) I-95 trip to/from Philly and Savannah. The trans would downshift on any slight grade at highway speeds. After the gear swap (with 32" tires shown in my signature pic) over the same route with the same load at the same speeds we got 9 MPG. The big difference was that it didn't downshift a single time at speed, those miles traveled in 3rd gear and high revs really knocks the MPGs down.
#132
#133
#134
#135
You should check to see if you have more than 2 injectors firing What is the theory behind running the tuner on Prem BUT burning Reg ?? I can't think that is to good on the engine ?? If it got me an extra 7 MPG I'd probably do it to though
