Door seal glue mess removal - Ford Truck Enthusiasts Forums
Old 06-30-2014, 08:08 PM
PancakeF150 PancakeF150 is offline
PancakeF150 is starting off with a positive reputation.
I have a question. Can the seal glue be removed easy? I bought a truck with new door rubber but the applicator person made a real mess of the areas that don't need glue. Acetone? or anything like that help me with cleanup?
Thank you in advance...
Old 06-30-2014, 09:23 PM
EffinSusie's Avatar
EffinSusie EffinSusie is offline
EffinSusie is starting off with a positive reputation.
You might try goo gone, if that doesn't work 3m makes a adhesive remover part # 6041
Old 07-01-2014, 06:48 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I'll second the 3M remover----it would be the safest method. Acetone will work but even on newer paint finishes it can be a bit harsh.
Typically that glue is a form of contact cement, most usually 3M's Super Weatherstrip Adhesive---their remover should work perfectly. NAPA either has or can quickly order it, use the number Susie provided.
Old 07-01-2014, 07:44 AM
Thank you very much.
Today is glue sniffing day. I think sniffing glue causes dain bramage. :-)
Glue removal? good to doo 1973 - 1979 F-100 & Larger F-Series Trucks 8 11-19-2016 11:22 AM
glue for door gaskets vidaliaman 1967 - 1972 F-100 & Larger F-Series Trucks 16 10-11-2016 01:48 PM
Super Glue - CA Glue CharlieLed 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 02-27-2016 01:41 PM
Door Seals falling off motorcarmike 1968-2013 Full Size Vans 8 02-13-2016 07:45 AM
tranny out next ? rfh129 1999 - 2003 7.3L Power Stroke Diesel 2 06-24-2015 12:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
