F150 supercab door stuck - Ford Truck Enthusiasts Forums
Old 06-30-2014, 08:02 PM
BOf250 BOf250 is offline
BOf250 is starting off with a positive reputation.
Hey guys new user here liking the forum so far . Anyways ive had a problem with my ,2001 F150 Supercab, one of my back doors on the driver side for a few months now is stuck. The door refuses to open ,when the handle is pulled the door pops, as if it is opening but the top part appears to be jammed or not releasing. I have come to the conclusion that it is a problem with a rubber piece in the mechanism that has worn over time.
I was wondering if any of y'all had any problems like this? If so what do you recommend I do to fix this. Thanks for any help
Old 06-30-2014, 09:03 PM
Marty N Debbie Sapp's Avatar
Marty N Debbie Sapp Marty N Debbie Sapp is offline
Marty N Debbie Sapp is starting off with a positive reputation.
More than likley it is the uper cable.
Old 06-30-2014, 09:24 PM
After searching the web some more I think your right. Though I wont know for sure until tomorrow or later this week when I have time to look for myself. Anyways thanks for the suggestion . I'll post the fix if it works.
Old 06-30-2014, 09:46 PM
Here is a fix I was looking for.
http://www.ebay.com/itm/Door-Handle-Cable-Repair-Kit-for-Ford-Vans-2-ends-equals-1-kit-/171182896854?pt=Motors_Car_Truck_Parts_Accessories&hash=item27db4bb6d6
Old 07-01-2014, 06:03 PM
Austin J.'s Avatar
Austin J. Austin J. is offline
Austin J. is gaining momentum as a positive member of FTE.
Is it both handles or just one? I had an issue where the rod for the inside handle came detached from the latch, but it fell down on to the magnet of speaker and i would pop when you pulled the handle from where is got stuck. The outside(covered by the front door) handle still worked fine.
2015 Lariat Left Rear Door (supercab) mantta 2015+ F150 5 12-04-2016 08:50 PM
Dome Light Problem Doubleubar 1999 - 2003 7.3L Power Stroke Diesel 7 02-24-2016 07:33 AM
Door stuck shut powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 9 07-10-2015 02:18 PM
05 supercab front doors wont shut fordboy_52 2004 - 2008 F150 6 12-22-2014 06:20 PM
Redundant question-Door Ajar Supercab Maxium4x4 1999 to 2016 Super Duty 0 11-23-2014 10:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
