boost problems 6.0
boost problems 6.0
Have a 03 f350 6.0 having problems with my turbo every time I accelerate and boost starts climbing gets to about 20psi it starts jumping real bad and black smoke and blowing off no power. But once it hits about 35psi runs great but when shifts dose it all over again. Need help thanks
[QUOTE=78fordman;14471996]You should not be getting to 35 psi. 28 psi max. Do you have a way to read live engine data? Such as a scan gauge or the android torque app? Need to know map baro and ebp at koeo. May be stuck turbo veins.
Sent from my leash using IB AutoGroup[ It is a built 6.0 about 825 horse power and has pushed max 37psi Evan tho its built should it not push that much. I put a new waste gate sensor in didn't help I heard of a boost pressure sonsor ? Cause it builds and starts like shooting off threw air intake boost gauge bounces all over. Still think the vanes
Just bought truck with all paper work on motor showing what has bin done got for a good price cause of this issue all ways had 7.3's trucks runs great except won't hold boost went over all the boots cooler. Up to 20psi runs great after that looses power and just starts bouncing all over. Those turbos easy to take apart and clean
Before this issue cropped up, of course....
Yes he gave me the prints of the dyno still was not sure cause I understand that's a lot. I tried to get it to the drags when they came to town to put on the dyno but didn't make it. Papers say yes but ive ridden in a few with the same and much more quick but still not sure it is all air ride lift about 12 inches with 22.5 alchola wheels has no problem moving until it gets over that point
Well, I think one of the problems is your rear end, you need to upgrade it to at least have Redline Ester based synthetic fluid and an external pump/cooler set-up. Those are some serious numbers, and you know, I'm sure, that driveline problems can work their way all the way back to the turbo, or really even the cold air intake this bad boy must have (look under the hood and see if one of those cone shaped K&Ns is of to the front drivers side).
This is going to take some work to diagnose, but I am confident we will get there!!
wycowboy
13
04-07-2005 11:22 PM
