Testing Oil Pressure Sending Unit
Working with Autometer to fix a problem where my oil pressure gauge is reading to high at times, we've got it narrowed down to the sending unit. Since I couldn't find this information elsewhere, I wanted to share what their tech told me for troubleshooting the sending unit.
To check the sending unit, measure the resistance across from terminal to ground with the sending unit disconnected from the gauge. Below are the readings you should find.
0 psi 242 ohms +/- 17
25 psi 152 ohms +/- 12
50 psi 103 ohms +/- 10
75 psi 66 ohms +/- 9
100 psi 30.5 ohms +/- 5.5
Hope this helps in troubleshooting a sending unit problem.
Muchopesos
07-27-2016 05:09 PM
TheRoadVirus
09-07-2007 01:04 AM
