Testing Oil Pressure Sending Unit - Ford Truck Enthusiasts Forums
Old 06-30-2014, 05:52 PM
powells_f150 powells_f150 is offline
powells_f150 is gaining momentum as a positive member of FTE.
Working with Autometer to fix a problem where my oil pressure gauge is reading to high at times, we've got it narrowed down to the sending unit. Since I couldn't find this information elsewhere, I wanted to share what their tech told me for troubleshooting the sending unit.
To check the sending unit, measure the resistance across from terminal to ground with the sending unit disconnected from the gauge. Below are the readings you should find.
0 psi 242 ohms +/- 17
25 psi 152 ohms +/- 12
50 psi 103 ohms +/- 10
75 psi 66 ohms +/- 9
100 psi 30.5 ohms +/- 5.5
Hope this helps in troubleshooting a sending unit problem.
Oil Sending Unit and Idiot Light RaleighDad66 1961 - 1966 F-100 & Larger F-Series Trucks 15 01-03-2017 08:46 PM
Help finding sending unit/gas gauge that are compatible. ford5.8 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-19-2016 06:18 PM
Aftermaket Sending unit bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 7 09-26-2016 12:43 PM
56 gas gauge, help an idiot . DR Smith 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 06-13-2014 03:36 PM
Installing autometer fuel gauge BigRobK 1967 - 1972 F-100 & Larger F-Series Trucks 5 06-10-2013 11:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
