Drive shaft slip yoke problem - Ford Truck Enthusiasts Forums
Old 06-30-2014, 02:40 PM
sperober1 sperober1 is offline
sperober1 is starting off with a positive reputation.
2000 f150 4r70w trans with the 2 piece drive shaft and that blue plastic that's on the slip yoke is pealing I think its the slip yoke anyways that goes inside the drive shaft slip yoke so now the slip yoke that goes over it wont fit is there any reason it shouldn't am I doing something wrong?
Old 07-01-2014, 07:47 PM
Dr. Dirt's Avatar
Dr. Dirt Dr. Dirt is offline
Dr. Dirt is gaining momentum as a positive member of FTE.
do you have any pictures?
75 Highboy driveshaft slip yoke orientation Colorado Highboy 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-21-2016 04:13 PM
Slip yoke E1TZ-4841-D ? Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 01-25-2016 08:05 PM
C6 Slip Yoke BushyTea 1961 - 1966 F-100 & Larger F-Series Trucks 2 05-02-2015 09:20 PM
1999 ford E250 slip yoke clunk? CopperBurst 1968-2013 Full Size Vans 5 03-21-2015 07:25 AM
bw 1356 slip to fixed yoke? RC Dan Clutch, Transmission, Differential, Axle & Transfer Case 2 08-25-2008 07:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
