What is this hose? - Ford Truck Enthusiasts Forums
What is this hose?
Old 06-30-2014, 10:27 AM
rlculver rlculver is offline
rlculver is starting off with a positive reputation.
What is this hose?
I have a 2005 Expedition and this hose is leaking at the T. Would it have anything to do with the a/c not working? Does anyone know what the part number is?
Old 06-30-2014, 10:54 AM
David7.3's Avatar
David7.3 David7.3 is offline
David7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to beholdDavid7.3 is a splendid one to behold
Rear heater hose for the heater coes
Old 07-02-2014, 03:13 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
The compressor won't run if the refrigerant is low. There are plenty of other reasons, like a bad fuse or compressor clutch.
Old 07-02-2014, 03:36 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
My AC stopped working once on my '04 F150 , I took it in to a trusted mechanic, turns out the bolts had come loose on the clutch , and he just bolted it back on , and 4 years later , works perfect
Old 07-04-2014, 10:41 AM
TransWorxs TransWorxs is offline
TransWorxs is starting off with a positive reputation.
If you have a test light/power probe check for power at the compressor. If it's not receiving power then check the low pressure switch. You might just have a leak to the point that the compressor won't kick on.
77 f100 custom - identify these hoses please. socalheel 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-10-2016 12:23 PM
Crankcase hose and vent assembly... what does it do? Ford SD 1987 - 1996 F150 & Larger F-Series Trucks 5 04-17-2015 09:16 AM
PCV valve change question choate 1987 - 1996 F150 & Larger F-Series Trucks 5 04-16-2015 11:10 PM
Leaking hose from master cylinder to power steering pump? mattdoc88 6.0L Power Stroke Diesel 5 02-08-2015 09:26 PM
Heater hose sizing on 93 Ranger 3.0? fatherdoug 3.0L V6 1 01-27-2004 08:06 AM
Tags
a/c, air conditioning, conditioner, hose, leaking
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
