1992 5.8 efi black smoke running rough
Old 06-30-2014, 10:26 AM
timbosliceee's Avatar
timbosliceee
timbosliceee is offline
hey I got a 5.8l efi that's running very rough, when idling will change idle speed constantly, it also has black smoke coming out of the exhaust, what should the first thing I check? its been sitting since October and the guy said it ran fine when he parked it.
Old 06-30-2014, 10:46 AM
c_root's Avatar
c_root
c_root is offline
Due to the excessive black smoke, I would say its overfueling badly. Try throwing some fresh fuel with a double dose of injector cleaner and floor the old girl. Also check for a rats nest or similar in the intake. Had that problem a year back with my old black f350. Cleaned out the intake box and changed the filter and it cleaned up the rich condition immediately. If not cold be a stuck injector. Best of luck
Old 06-30-2014, 10:52 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
Welcome to FTE!
Sure sounds like its pig rich. Need to check fuel psi. Sounds like it's the Fuel Pressure Regulator.
Also, could be a leaking injector. Try removing the vacuum hose from the nipple on the FPR and see if fuel is evident or running out of it.
And last but not least, Check for Codes!
Report back with results.
Old 06-30-2014, 11:04 AM
timbosliceee
thank you will try that out!
Old 06-30-2014, 05:05 PM
Crewcabber's Avatar
Crewcabber
Crewcabber is offline
I would seafoam it. Go get two cans of Seafoam. Read the instructions. I can to mainline thru the brake booster vac. line and one can to put in the tank start with that then start replacing parts.
Ford_Six
1997-2006 Expedition & Navigator
10-21-2021 06:46 PM
Venom76
Large Truck
01-03-2021 11:33 PM
ldfry001
07-10-2009 04:24 PM
rambo5561
11-24-2008 08:08 PM
FlairSide
07-18-2007 02:11 PM
Quick Reply: 1992 5.8 efi black smoke running rough
