Auto trans behind flathead - Ford Truck Enthusiasts Forums
Old 06-30-2014, 08:27 AM
tip49's Avatar
tip49 tip49 is offline
tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.tip49 has a great reputation on FTE.
I have a line on an 8BA flattie, and am currently running an AOD transmission. Have done some research but has anyone actually spent the money to bolt one up ? It may turn out that the flathead may not be salvageable but I would like to plan for best case scenario.
Tom
Old 06-30-2014, 10:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
C-4's are pretty common behind flatties so it should be possible to put an AOD off a 302 behind one. Hooking up the throttle cable would be the tricky part, I'd guess. Try a google search, somebody on the HAMB or Ford Barn is sure to have tried it.
Old 06-30-2014, 04:22 PM
tip49's Avatar
Thanks Ross
I would be a long way off, but may pick up the flattie this summer/fall
Old 06-30-2014, 04:28 PM
NC-51-F1's Avatar
NC-51-F1 NC-51-F1 is offline
NC-51-F1 is starting off with a positive reputation.
Speedway has a kit...
910-28907 from Speedway Motors, America's Oldest Speed Shop
I'm sure the individual parts are available if you already have the trans.
Hope this helps...
Rear van heater Tom Callan 1968-2013 Full Size Vans 8 02-02-2016 07:58 AM
1990 f350 brake rotors. rbtom 1987 - 1996 F150 & Larger F-Series Trucks 1 08-24-2015 09:06 AM
WTB Ranch Bumper for 2000 F250 Two000F250 WTB - Parts & other 0 12-11-2014 09:59 AM
How to bench-test a 6-volt temp sensor (updated) pineconeford 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-18-2014 08:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
