4 speed trans mount
Patrick
Post your location in the upper right hand corner, you do it by going through the control panel you used to sign up for the board. If you have your location posted there might be someone in your general area, or immediate area, that can help with working on your truck and locating parts.
You can also list your truck, year, model in your signature. (see below) This will clarify what truck(s) you have. You can install a signature through the control panel.
Here is a thread with pictures: https://www.ford-trucks.com/forums/1...l#post10483970
In it, MTFlat shows a HD 3-sp in an F-1 with the same semi-circular mount as a LD 3-sp. And Havi shows a 4-sp in an F-1 that uses the same. The rear bearing retainer was changed for F-2 and higher to use the "hoop" crossmember with the flat rubber mount.
thundersnow70
03-17-2018 07:49 PM
Poes
16
11-25-2014 06:54 AM
thrifty
06-02-2011 04:25 PM
rich51fordtruck
05-22-2006 05:34 PM
