4 speed trans mount - Ford Truck Enthusiasts Forums
4 speed trans mount
Old 06-29-2014, 09:59 PM
jonesa49f1 jonesa49f1 is offline
jonesa49f1 is starting off with a positive reputation.
4 speed trans mount
I have been looking for the mount for my 4 speed tranny and have not been able to find one does anyone know where I can get one or how to make one?
Old 06-29-2014, 10:42 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
21A-6068-A .. Rear Rubber Engine Mount / Reproduced by Carpenter.
1948/52 F1.
Lower pic, C = F1.
Old 06-29-2014, 11:23 PM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
If you want answers to questions as vague as this you need to provide info, e.g. what year truck, what motor and mount set up, what type of 4 speed, get my drift. Can you weld, bend metal, skill level, etc.... You want help, provide us with the proper tools to help.
Old 06-30-2014, 12:16 AM
41505379's Avatar
41505379 41505379 is offline
41505379 is starting off with a positive reputation.
Quote:
If you have an F-1 and are looking for the big cross member that the f-2 and f-3s use to mount the 4 speed spur transmission on, I have one attached to a frame. I intend to only use the rear of the frame and could sell the crossmember to you. Don't know if that is what you are looking for though.
Patrick
Old 06-30-2014, 08:27 AM
Yeah it is the rear trans mount mounts to the frame my mount the rubber is all rotted out and when I took my motor and trans out the mount fell apart.
Old 06-30-2014, 10:30 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Post your location in the upper right hand corner, you do it by going through the control panel you used to sign up for the board. If you have your location posted there might be someone in your general area, or immediate area, that can help with working on your truck and locating parts.
You can also list your truck, year, model in your signature. (see below) This will clarify what truck(s) you have. You can install a signature through the control panel.
Old 06-30-2014, 11:54 AM
41505379's Avatar
Big crossmember/trans mount
Is this what you need? my cell is 636-489-9742 Patrick
Old 06-30-2014, 11:58 AM
bobj49f2's Avatar
His frame is OK, he needs the replaceable mount.
Old 06-30-2014, 05:21 PM
1952henry's Avatar
1952henry 1952henry is offline
1952henry is gaining momentum as a positive member of FTE.1952henry is gaining momentum as a positive member of FTE.
If you are looking for the long rubber piece joblot has them. I just got one a few weeks ago
Old 06-30-2014, 06:48 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Unless I'm mistaken, a 4-sp in an F-1 uses the same semi-circular mount as the LD and HD 3-sp's. Only the trannies in F-2 and F-3+ have the deep crossmember.
Old 06-30-2014, 07:19 PM
1952henry's Avatar
You are probably correct Ross
Old 06-30-2014, 07:45 PM
bobj49f2's Avatar
I was looking through a couple of web sites over the weekend, one stated that their rubber was only for the F-1 three speed while another didn't differentiate between the two, just sell "all".
Old 06-30-2014, 07:58 PM
ALBUQ F-1's Avatar
postin' fool
Here is a thread with pictures: http://www.ford-trucks.com/forums/10...l#post10483970
In it, MTFlat shows a HD 3-sp in an F-1 with the same semi-circular mount as a LD 3-sp. And Havi shows a 4-sp in an F-1 that uses the same. The rear bearing retainer was changed for F-2 and higher to use the "hoop" crossmember with the flat rubber mount.
Old 06-30-2014, 08:26 PM
Look at post 2, the rubber mount is illustrated, as is the parts catalog applications and part number.
2004 Sport trac V6 P0715: Input/Turbine Speed Sensor Circuit radmacks Explorer, Sport Trac, Mountaineer & Aviator 1 09-12-2016 11:32 PM
Transmission mounts obscurity 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-31-2016 10:01 AM
Replace 460 engine mounts H311RA151N 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 24 04-06-2016 01:03 AM
engine /Trans mount newguy399 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 06-01-2015 09:47 AM
Block plate help! Mac78 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 43 01-25-2015 07:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
