2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 expedition won't start after plug change
Old 06-29-2014, 04:36 PM
Vt1100c203's Avatar
Vt1100c203
Vt1100c203 is offline
I just replaced the spark plugs on my 07 expedition after having the slight stutter in overdrive. Although difficult (all 8 broke even after following all of the advice) I was able to remove them with the lisle tool. I reinstalled the plugs (new motor craft), coils (original, did not change), etc and started it up. It took a few cranks to get it going, but it finally started. I let it run for a while and it was just a little rough. I decided to remove everything again and check the plugs/coils/ etc. Everything seemed ok, so I reinstalled everything. Now it won't start at all. It cranks. I triple checked all of the connections (looked for bent pins, looseness, etc.). Everything looks fine. I also checked all of the ignition related fuses. Please help! I spent all weekend breaking a vehicle that only had a minor stutter! Any advice would be greatly appreciated.
Old 07-10-2014, 10:47 PM
gwcloud's Avatar
gwcloud
gwcloud is offline
I am wondering if you ever got your Expedition running after the plug change. If so, what was the cause of the problem?
Richard
tevans213
02-01-2016 04:37 PM
J ballan
1997-2006 Expedition & Navigator
11-28-2014 02:46 PM
ccd1977
27
01-15-2013 09:24 PM
efair
11-22-2010 07:23 PM
vjstangelo
Modular V8 (4.6L, 5.4L)
04-11-2008 09:13 PM
Quick Reply: 2007 expedition won't start after plug change
