2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
'07 Expedition cranks, won't turn says low oil pressure
Old 06-29-2014, 02:31 PM
Michael Sharpe's Avatar
Michael Sharpe
Michael Sharpe is offline
I have a 07 Expedition that will not start. I went out one morning it started I backed up and then the engine shut itself off. It did not sputter and die, it turned off. I turned the key and it cranks normally but for about 10 seconds on one turn. Then the oil light came on. I went through many forums and the best I could come up with is oil sending unit is bad. Replaced it, changed the oil and the filter yet it still does the same thing. It was making no noises and the pressure had never fluctuated previously. The gauge will read pressure while cranking then drop to nothing when it is done cranking and the oil light comes on along with the check engine light. Does anyone have any idea what it could be or solutions? Thank you for any future help.
Old 06-29-2014, 02:59 PM
Michael Sharpe
I disconnected the battery to see if the computer reset that would fix the issue since I just installed a new oil pressure sensor. However it did not fix it still does the same thing, however now the CEL blinks at me instead of staying solid.
Old 07-01-2014, 10:45 AM
berry1234's Avatar
berry1234
berry1234 is offline
Time to take it in. Throwing parts at a fix is expensive and rarely fixes the issue. Need someone with experience with mod motors.
Jonathan Martin
07-08-2019 07:05 PM
mcbridec
1997-2006 Expedition & Navigator
10-31-2013 11:18 AM
jafy31601
06-16-2011 08:56 AM
Quick Reply: '07 Expedition cranks, won't turn says low oil pressure
