General Diesel Discussion
EPA acknowledges that current emissions standards effect reliability
Old 07-31-2014, 09:29 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Originally Posted by BruteFord
Just stumbled on that Ford did a diesel ranger in the 80s.
You see one every now and then on Ebay. They seem to go for
the price of a small load of cash.
BTW I am all for an EPA Delete.
Sean
  #32
Old 10-30-2014, 09:14 AM
w6pea's Avatar
w6pea
w6pea is offline
Originally Posted by parkland
The ultimate emission delete would be to simply delete the EPA altogether.
What a waste of money.
People want clean running vehicles anyways, let manufacturers figure it out on their own without intervention.
That can't be done soon enough. How about CARB also. (California Air Resources Board.)
  #33
Old 10-30-2014, 09:20 AM
w6pea's Avatar
w6pea
w6pea is offline
Originally Posted by Driver Jim
The EPA never gives enough time for new engine technologies to be found. I mean, come on. It's a known FACT that one can stand in a room with a RUNNING diesel and -so long that it's running right- suffer virtually NO serious health effects.
But naturally they have to interfere with a system that worked, introducing Diesel Exhaust Fluid. Yes, DEF exists. Just ask the truckers that keep the good moving lining those environmental yahoo's pockets about it.
DEF is nothing but watered down, dyed cow ****. Literally, when the system has a UREA sensor. And for what, a few HCs? BAH! Of course injecting DEF into the exhaust stream generates NOx just to make life even better.
The EPA is like the IRS. They want results NOW, but don't care to work with others to make them happen.
What year Ford Diesel is not required to run DEF ?
I want to replace my truck. I have a 95 I am very seriously thinking of buying a newer Super Duty, instead of rebuilding my truck. I was going to put a motor and trans and repaint it, then some scumbag from Baja Ca. backed into the right rear side of my truck. (it had no dents or dings in it before a week ago today)
  #34
Old 10-30-2014, 01:59 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
up to and including 2010 model year no def fluid , 2011-2015 model year def fluid required, unless you delete the emissions equipment.
  #35
Old 10-30-2014, 11:09 PM
w6pea's Avatar
w6pea
w6pea is offline
Thank you for the info.
  #36
Old 10-31-2014, 12:23 PM
parkland's Avatar
parkland
parkland is offline
Anything 2008 or newer has the exhaust filter though, which on it's own without DEF, is actually worse.
The 1999 - 2003 7.3 trucks had no emissions junk.
The 2003-2007 6.0 trucks had EGR.
The 2008-2010 6.4 trucks had EGR, and DPF, and are common rail.
The 2011+ trucks have EGR, DPF, and urea injection.
82_F100_300Six
04-11-2019 07:51 PM
F-250 restorer
10-07-2011 10:16 AM
luny1
16
02-11-2010 09:21 PM
Diesel Man
6.4L Power Stroke Diesel
24
10-19-2008 04:55 AM
DonsFx4
General Automotive Discussion
03-23-2005 06:02 PM
Quick Reply: EPA acknowledges that current emissions standards effect reliability
