Ford C8000 Won't Start: Battery Smoking - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-29-2014, 07:05 AM
coalnation's Avatar
coalnation coalnation is offline
coalnation is starting off with a positive reputation.
Question Ford C8000 Won't Start: Battery Smoking
Like the title says, out of nowhere my engine decided it did not want to start and when I do try and start it, one of my batteries smokes. Obviously I didn't want to let it try and turn over for a lengthy time because of the smoke. Before this is fired up perfectly.
Does anyone have any clue as to where I should start looking for the problem?
Old 06-29-2014, 01:32 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Cables, connections and the starter itself.
You may also want to perform a load test on the battery with a battery tester if you can find one.
Cables can corrode inside the insulation, and especially at any junction with a connecter.
Old 06-29-2014, 08:10 PM
Slowpoke Slim's Avatar
Slowpoke Slim Slowpoke Slim is offline
Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.Slowpoke Slim has a very good reputation on FTE.
Sounds like a dead short while cranking to me. Look at starter and solenoid.
Old 06-30-2014, 12:29 AM
80broncoman 80broncoman is online now
80broncoman is gaining momentum as a positive member of FTE.80broncoman is gaining momentum as a positive member of FTE.
X2 on that last line for sure.
Very true. They can look fine and have all kinds of corrosion in there on the copper.
Old 06-30-2014, 07:26 AM
coalnation's Avatar
Thanks for the input. I'll go check it out soon.
Old 06-30-2014, 04:38 PM
coalnation's Avatar
Granted everything is rusty as hell, the connections seem okay. Is anything supposed to go on the empty post in the front? I did have one loose wire near everything.
Old 06-30-2014, 06:37 PM
coalnation's Avatar
Well I replaced all the connectors and cleaned the hell out of everything. I guess this story has a happy ending.
<iframe src="//www.youtube.com/embed/NdzLTmXfGcY" allowfullscreen="" frameborder="0" height="360" width="640"></iframe>
Old 06-30-2014, 06:46 PM
With all that rust I'm surprised that the solenoid was still grounded.
For that matter If (when) you have other electrical problems on that vehicle always check your grounds.
Old 06-30-2014, 08:21 PM
coalnation's Avatar
Starting "Operation Destroy All Rust" in the morning.
Problems - Cold Start/White Smoke: EGR Cooler, Oil Cooler, Injectors, FICM? karter81 6.0L Power Stroke Diesel 6 02-26-2016 02:23 PM
Electrical system has gone haywire after having 2 new batteries installed kellygirl000 Excursion - King of SUVs 17 07-14-2015 10:14 PM
Generator issues.. fifty-two_f1 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 08-20-2014 11:14 AM
no power fatkid89704 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 06-15-2014 10:22 PM
Time for new battery/batteries... f350rebel7788 1994.5 - 1997 7.3L Power Stroke Diesel 76 11-09-2011 01:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
