RELAY PROBLEM PLEASE HELP.
I recently had a problem with my truck turning off on the highway. It would crank back up but once it got home and parked it died and would only turn over. Had a mechanic come over and he replaced the IDM relay and it cranked and ran GREAT )Dead for over a month). My question is why would the relay blow stop working? If it's a short where do I even start.
Relay failure could be because of loose connections in the BJB (Battery Junction Box)
where the FICM relay is located. A loose connector tends to get worse do to the fact that
is it loose and will have some heating do to current and higher resistance at that
connection. You need some type to tool ie a gauge set that will read live data so you
can see what the numbers are for each thing that would need to be checked and verified.
FICM main power being one of the things along with logic power and so on.
If the FICM is not getting main power or battery voltage then it's back to the relay or
the connector plugs.
Sean
Sean
No it ran fine and randomly shut down on the highway. It started back up and drove home then it cut off right when I parked it. At that time it would only turn over. It sat for a while until I could get a mechanic out to look at it. The last resort he tried was to swap the blower relay with the IDM and then it started right up. When it was running my AC wouldn't blow anymore so that prooves the one that he swapped and put in the blower spot is broke. But why would any of that even happened? I know relays can fail but it's like this one sometimes worked and sometimes didn't. It was the original relay in that spot I believe. 280,000 miles
Sean
Sean
It held up for 280,000 miles so it wasn't like it was brand new. Do relays just go bad over time? And even if they do how would that explain why it would die but start back up. Can they relay work sometimes and not?
repeated closing of a relay into a faulted circuit can ruin the contacts. You would also have several blown fuses and such. I would replace the relay and call it good. I am an electrician by day and this sort of thing happens, anything mechanical wears.
