lowering front end on 52 F-1 - Ford Truck Enthusiasts Forums
Old 06-28-2014, 04:03 PM
retro48/52's Avatar
retro48/52 retro48/52 is offline
retro48/52 is starting off with a positive reputation.
Hello, I am going to lower my front end 2" - 2 1/2" from stock. Right now I have a stock front end with a sway bar and a dampener attached to the I frame from the stock axle. My question is when I lower the front by taking out some leaf springs, will that change my camber, caster, alignment, etc?
I read that I might have to place some 2 or 4 degree shims in to get it back to standard measurements.
Has anyone completed this and if so, how many degrees did you have to use to shim your front end with to get it to standards?
Thanks for reading and all your help. You guys are the experts, I am a lonely apprentice......LOL.
Dennis
Old 06-28-2014, 10:11 PM
96XL 96XL is offline
96XL is starting off with a positive reputation.
Dennis,
I am in Denver as well (north about 20 min). I went back and forth a few times deciding how to lower the front of my 52. For me I finally decided to pull the trigger in a set of dual leaf posies. They claim 3" drop over stock. After reading a few threads of people removing leafs on the front I decided the best option for me was replacement. I also toyed with the idea of getting the stock axle dropped by nostalgia sids in OK. I don't have any real world measurements yet as I am still rebuilding the steering before I get it back on the ground. As far as alignment specs, doing tow yourself is easy. Caster can be measured at home as well. This is easily adjusted by shims between the axle and the springs. For me I am going to get it all back together and see how it feels before I change any shims. Do some research on the jeep forums as a ton of that info is applicable.
We should connect sometime. Where are you at?
Byron
Old 06-29-2014, 02:35 PM
retro48/52's Avatar
Byron....PM sent.
Old 07-01-2014, 12:27 AM
gearhead1952's Avatar
gearhead1952 gearhead1952 is offline
gearhead1952 is gaining momentum as a positive member of FTE.
If you are just pulling a leaf or two that won't change your alignment as long as you leave in any caster shims under the leaf springs. You want 6-7 degrees caster. I believe the posies springs come with caster shims.
Old 07-01-2014, 03:14 PM
petemcl's Avatar
petemcl petemcl is online now
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
I went the Posies Dual Flex route on the front and per their recommendation their Super Sliders on the rear wit Bilstein shocks on the front. I got a 2-3" drop. Here are some pictures. http://www.ford-trucks.com/forums/1306571-posie-question.html#post14401997
steering wander corrected, 5 degrees of caster fastang50 Excursion - King of SUVs 119 12-09-2016 04:32 PM
6 Cyl Swap 52-F2 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-01-2015 09:21 PM
Help with shackles/ lowering truck ryansmith159 1973 - 1979 F-100 & Larger F-Series Trucks 17 06-12-2014 11:49 AM
2 Lift thread with pictures, math and theory smoky_diesel 6.7L Power Stroke Diesel 34 05-28-2014 12:47 AM
lowered guys look here Thumper19 1987 - 1996 F150 & Larger F-Series Trucks 51 02-02-2012 11:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
