Portland Oregon, Help! Anyone have Autoenginuity to help diagnose 6.0 injectors
#48
Well I just installed the boost gauge (psi) on my scangaugeII that amdriven2liv suggested. in park at full throttle i can only see 5-6psi, and that is while blowing blue smoke and with alot of sluggish throttle response and engine shake, like an injector is not contributing correctly. Just a thought, i had a local shop put a new turbo on and I am wondering if the Y-pipe is not hooked up correctly, limiting boost. I looked over the Y-pipe but could not see anything out of place.
So the question is could a low or no boost issue cause an engine to act like it is having low power and or and injector issue?
Your thoughts Guys?
Your thoughts Guys?
#49
taildragger,
In park at full throttle you aren't going to see the kind of boost you would if you were at full throttle on the highway.
In park and at idle you should see 0-.5 psi. (VGT would be somewhere between 65% - 85%)
While cruising on a nice flat road with little load you would see something like 4psi - 8psi. (VGT would be somewhere between 45% - 6x%)
And then mashing the pedal to the floor while on the road you should see somewhere between 24psi - 28psi. (VGT would be somewhere between 16%-2x%)
An exhaust leak or boost leak will definitely cause low power if the leak is big enough.
You might also pull and clean your EGR if you haven't already done that. And then monitor that with the ScanGauge.
Another item to check is the MAP hose that runs from a nipple on the intake to the MAP sensor. That port could be plugged up or the hose cracked or have a small hole in it.
Also, the ScanGauge can monitor for injector misfires. I've never used that part of the gauge so I'm not sure how good or accurate it actually is.
#51
Unfortunately, the shop was not willing to let a good FICM out the door, and I understand. They were real nice about turning me down.
If Wednesday afternoon works for you I am up for swapping our your FICM for a test. I think Yahiko was offering to make a road trip and bring his Ford VCM down and hook it up. I will reach out to him and see if he is still available.
Yahiko, what say you, does Wednesday work for you as well?
#55
#56
#58
Well, we swapped FICMs. Didn't change the situation very much. He did think the throttle response was better, but, I might have to think that my FICM has the Atlas 40 on it, while his doesn't.
When I got there, we scanned for codes and got some. Hopefully Kyle will post those up. (we then cleared the codes)
We started and ran the truck numerous times, didn't run it on the road, and none of the codes returned. Now, I must add, the Torque APP called them grey codes and none of them had set the CEL.
#59
#60
Thanks Sean for being willing to offer up your FICM and your time to help diagnose the above stated problems I have been struggling with! I am amazed at the willingness of this Group of 6.0 owners and enthusiasts who are up for helping new members (strangers) without a second though.
Most of us are on a budget and want to make wise decisions on what we repair and how much to spend or do ourselves. With the kind of help and support this forum and its members offer it sure makes it easy for me to look forward to tackling many future repairs and mods.
So thanks again.
Next step?
After ruling out a FICM issue, Fuel filters, Turbo, ICP, HPOP, IPR, EGR, Stiction (using Hot Shot Secret cleaner). I am left with looking hard at a injection issue (mechanical or electrical). If I am lucky Yahiko may be able to swing by this week with his Ford Diagnostic program so we can look at the injectors specifically.
Both Sean and I have tried using the ScanGaugeII and the Torque APP, and have been unable to see them record or indicate injector misfires or issues. Unsure if anyone else has had luck with this.
On a side note, I will post a picture of damage to my Air Intake boot at the turbo. The boot was not installed correctly after the shop replaced the Turbo. The incorrect installation crushed one side of the boot tearing the rubber after it was pinched by the clamp. This has caused a obvious air leak upstream of the MAP sensor. This issue is not related to the possible injector issue but would cause some issue I am sure.
I will followup with more soon.
So thanks again.
Next step?
