On our way camping the door ajar light came on. Ive check every door and they are closed. I couldn't tell where the door switch is so I had to pull the fuse for now since the dome light and cargo light wont turn off.
Any advice where to start or something that may be common?
Switches are built into the latches in the body panel. Spray with WD40 and open close doors till it clears. Unfortunately the display doesn't tell you which door. One out of four you hit it on the first one. Good to lube all of them anyway.
Switched are built into the latches in the body panel. Spray with WD40 and open close doors till it clears. Unfortunately the display doesn't tell you which door. One out of four you hit it on the first one. Good to lube all of them anyway.
Hmm, Mine does. But he is right spray and work the latch a
few times and it should go back to working.
