Edge Evolution CS - Ford Truck Enthusiasts Forums
Computer Chips & Tuners SPONSORED BY:
Edge Evolution CS
Old 06-28-2014, 07:46 AM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
Edge Evolution CS
Have this programmer installed on my 2005 F150 4.6 4.88 gears, 9.75 diff, on 35s. With the programmer plugged in the ABS dash light comes on and stays on. Even stays on once Edge is unplugged. Only method to have ABS light turn off is go flash the truck module. While the Edge is plugged in the speedo works but is off by 5-15km/h depending on actual speed. The Edge speedo is basically accurate. Once the Edge is unplugged the truck speedo does not work at all. The speedo needle stays limp at the bottom and does not register a speed. Have the Edge unplugged to keep ABS light from coming and staying on.
Any assistance on this problem would be helpful. Heard that 5 Star can delete the programs on the generic Edge I have and install better programming. Is this correct?
01 F250 ABS/Speedo fancyketchup 1999 to 2016 Super Duty 3 02-20-2015 11:15 AM
Not another "ABS light on" thread polish dude 1999 to 2016 Super Duty 1 01-15-2015 10:18 PM
ABS dash light tjcprop 2004 - 2008 F150 2 06-14-2014 01:05 PM
edge programmer. jes01srw350 1999 - 2003 7.3L Power Stroke Diesel 0 06-01-2014 10:33 AM
Speedo tjcprop 2004 - 2008 F150 8 04-18-2014 07:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
