4-link mount inboard or outboard? - Ford Truck Enthusiasts Forums
Old 06-27-2014, 11:46 PM
Trey_Morgan's Avatar
Trey_Morgan Trey_Morgan is offline
Trey_Morgan is starting off with a positive reputation.
I recently purchased a triangulated 4-link kit for my 1951 F-1. Now this kit came nicely built with all the hardware and bushings. My question is how did you mount your lower bars? And if your running a parallel kit you can also chime in. I'm wondering because it would make things a lot easier if the lower bars mounted outside the frame rails. I'm not sure how its supposed to be done exactly. I've seen set ups both inboard and outboard. What are the pro's and con's to both options?
Old 06-27-2014, 11:53 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The lowers outboard and parallel to the frame rails will work fine. I've seen kits that utilize the original rear spring front hanger for the forward bar mount. Most OEM vehicles have the upper bars close to the center section on the rear end and angled out toward the frame rails.
Old 06-27-2014, 11:59 PM
That was how I originally planned on setting it up but after researching how others did theres I see a lot of different styles and bar placement. I plan on running a set of air bags and have noticed most guys have there upper links mounted center on the cross member and out on the axle tubes? Is there a reason for that or am I over analyzing things?
Old 06-28-2014, 03:51 AM
trumph trumph is offline
trumph is gaining momentum as a positive member of FTE.
Hey Trey i went the other way with mine centered on the diff housing and out at the front to the Chassis rails which i plated in
Old 06-28-2014, 09:27 AM
51dueller's Avatar
51dueller 51dueller is offline
51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.51dueller has a great reputation on FTE.
It depends on the type of rear axle you have and where you have the center bars. The differentials with the nodular iron housings you can't weld to the center section without a truss. Others like the 9" have a steel housing which is easily welded.
Old 06-29-2014, 07:08 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
I mounted mine wide at the axle and narrow at the frame. I had to make a cross member to do this. I mounted mine directly under the frame so that i didnt have to modify the rear running board bracket or the existing cross member. This is with the welder series kit.
Edit here is the picture
Old 06-29-2014, 07:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
I would assume for a set of bars already purchased, in specific lengths, you need to install them the way they were designed to get the correct geometry. Have you asked the vendor? Were there any layout drawings?
Old 06-29-2014, 08:23 PM
No drawings or instructions with the kit. I can call them and ask but after some measurements taken today I realized I'm in a pickle ether way. Inboard I need to redo my crosmember if outboard I have to move the rear running board mount.
Old 06-29-2014, 08:35 PM
Gicknordon's Avatar
Quote:
Thats exactly why i mounted mine under the frame.
Old 06-29-2014, 08:47 PM
Quote:
I would mount mine under but I plan on using a set of air bags. The link bars being under the frame I think will limit the travel and become a low point on the frame when the bags are deflated.
Old 06-29-2014, 08:58 PM
Gicknordon's Avatar
Where did you buy your kit from? Since the bottom bars are supposed to be parallel to the ground at ride height, if you use a supplied mount on the axle the front of the bar will be at the same height no matter if you mount inside outside or under your frame
Old 06-29-2014, 09:24 PM
(http://www.johnnylawmotors.com/catalog/1974-1978-mustang-and-pinto/rear-suspension/rear-four-link-kits/VPATTK4/heavy-duty-triangulated-universal-four-link-kit-with-shock-hardware)
This is the kit I ordered.
Old 06-29-2014, 09:29 PM
ALBUQ F-1's Avatar
postin' fool
Did you download the instructions from that page? What do they say?
Old 06-29-2014, 09:35 PM
Gicknordon's Avatar
Youll have to play around with where it will fit best. like i said the front of the bar will be at the same height no matter what, itll be a question on if there will be clearance to the frame under full travel if you mount it underneath the frame.
Dont know if thats enough travel for what you want to do, but it bottoms out at the axle tube before the bar hit the frame. Like you said youll have to modify either the cross member or running board bracket if you go one of those ways.
Old 06-29-2014, 11:00 PM
It says to mount inboard but it also says they can be shortened if needed. I can take 5 inches out of the lower bars and they will clear the factory croess member.
If I shorten the lower bars do I need to also shorten the uppers?
In order to get the lower bars parallel with the world at ride hight I think my best option is like yours. Shorter lower links will make them even more of an angle at ride hight.
Warn locking hubs install problem wrdabney 1999 to 2016 Super Duty 18 10-07-2016 04:29 PM
OE Sway Bar End Link Replacement with Pics Y2KW57 1999 to 2016 Super Duty 25 06-08-2016 08:35 PM
Dana 50 TTB re-assembly help request...did I say HELP..???? wtrbrdm 1987 - 1996 F150 & Larger F-Series Trucks 2 07-05-2015 12:24 PM
2014 Super Duty Wheel Offset and Tire Questions/Input RRRAVEN 1999 to 2016 Super Duty 2 01-02-2014 11:19 AM
Rear leveling Airbags-inboard or outboard? Kookadala 1999 to 2016 Super Duty 5 03-15-2007 03:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
