4-link mount inboard or outboard? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 01:05 PM
schoo's Avatar
schoo schoo is offline
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
So trey what happened with the diff? Did you get another
Or did I miss something
Old 06-30-2014, 02:30 PM
Wayne Waldrep's Avatar
Wayne Waldrep Wayne Waldrep is offline
Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.Wayne Waldrep has a very good reputation on FTE.
Just for our reading pleasure here are the instructions....Just me but I'd definitely use all the tabs provided and I'd also prefer mine to be all on the axle tubes. I also like trumps front mounts on the upper bars. That looks good. And another one of my crazy thoughts would be that unless I just had to, there's no way I'd shorten the bars. Just my thoughts though.
Old 06-30-2014, 03:05 PM
Trey_Morgan's Avatar
Trey_Morgan Trey_Morgan is offline
Trey_Morgan is starting off with a positive reputation.
My original plan was a ford 9" I picked up but it turned out to be from a van so it was wayyyy to wide. Back at square one I deiced I will be happier with a explorer 8.8 which a friend of mine has one for $250.00 so I'm going to pick that up and go that route!
Old 06-30-2014, 11:14 PM
schoo's Avatar
Will be waiting to see how you do that
Old 07-01-2014, 03:00 AM
trumph trumph is offline
trumph is gaining momentum as a positive member of FTE.
Trey i read with mine that the short arms still need to be at least 70% of the longer bars just as a rule of thumb but looking at Gicknordons im going to have to make new brackets and lower the front of the longer arms to a more parallel position as in waynes instruction pictures
Warn locking hubs install problem wrdabney 1999 to 2016 Super Duty 18 10-07-2016 03:29 PM
OE Sway Bar End Link Replacement with Pics Y2KW57 1999 to 2016 Super Duty 25 06-08-2016 07:35 PM
Dana 50 TTB re-assembly help request...did I say HELP..???? wtrbrdm 1987 - 1996 F150 & Larger F-Series Trucks 2 07-05-2015 11:24 AM
Replacing Holley 4180 w/Carter 9637S AFB Carb bigwalt1 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 7 07-16-2014 08:14 PM
Rear leveling Airbags-inboard or outboard? Kookadala 1999 to 2016 Super Duty 5 03-15-2007 02:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
