Towing Capacity F250 6.2L Crew Cab 3.73 Axle - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 06-27-2014, 11:09 PM
haffner226 haffner226 is offline
haffner226 is starting off with a positive reputation.
What is the recommended towing capacity of a 2013 F250 6.2L Crew Cab with a 3.73 axle. I read that the capacity is 12400, but that seems low. Any help would be appreciated. Looking at buying a 5th Wheel with gross of 15,500.
Thanks,
Old 06-28-2014, 03:31 AM
Butl85 Butl85 is offline
Butl85 is starting off with a positive reputation.
Quote:
Thanks,
That is your capacity. For 15.5 you are going to need a diesel. I would have to look it up but I think the only 6.2 that might put you near 15,500 is a 350 single cab with 4.30 gears.
Old 06-28-2014, 05:51 AM
T diesel T diesel is online now
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
The heaviest you can tow with a 6.2 is 15,700lbs.
F-350 drw 4x2.
http://www.ford.com/resources/ford/g..._SuperDuty.pdf
Old 06-28-2014, 08:40 AM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
My 2013 SC 2wd DRW 4.30 gears is rated to pull 15600, our trailer is 15900 last year when I weighed. Your biggest problem is the 3.73 gears and the weight you will be putting on the truck, our trailer puts 3200 to 3400 lbs on the pin. You also have to look past all the ratings and look at the trailer, will it have standard undersized brakes that most units come with or have they been upgraded, when we ordered ours we upgraded to Dexter HD brakes 12 x 2 to 12.25 x 3.375 big difference. Remember it's not only pulling it it's also stopping.
Denny
Old 07-15-2014, 02:05 PM
-brent's Avatar
-brent -brent is offline
-brent is starting off with a positive reputation.
Good point!
Old 07-23-2014, 08:42 AM
Retread65 Retread65 is offline
Retread65 is starting off with a positive reputation.
** What Denny said !! **
It can't be said enough times. I saw a 12,000 lb travel trailer being pulled with a Chevy Luv once and I got as far away from them as fast as I could. I'm sure they were proud of themselves.
Old 07-23-2014, 09:33 PM
BigMix's Avatar
BigMix BigMix is offline
BigMix is starting off with a positive reputation.
As for brakes, my understanding was that all 13's and newer had larger rotors than the 11's and 12's. I didn't even realize that there was a better option.
Old 07-23-2014, 09:40 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
Quote:
The better brakes being referred to above is on the trailer not truck
rvpuller's Avatar
If your talking about my post I was talking about upgraded brakes I ordered as a option on our trailer.
Denny
Old 07-23-2014, 09:59 PM
BigMix's Avatar
Quote:
Denny
As I read that again, it was clear you were referring to the trailer. Too long of a day at work I guess.
F250 conventional towing discrepancy qflyer Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 26 01-17-2015 08:10 AM
Travel trailer with a F150 CPL_Guimonster 2015+ F150 8 09-16-2014 08:30 AM
trying to figure out axle ratio F-250beast 1999 to 2016 Super Duty 5 11-14-2010 12:52 PM
6.2L with 3.73 or 4.3 thoughts fw2500 6.2L V8 30 10-04-2010 08:01 AM
Gross Vehicle Towing Capacity 1L243 Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 2 07-16-2010 12:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
