T10 Transmission Throwout bearing - Ford Truck Enthusiasts Forums
Old 06-27-2014, 09:15 PM
Jasonnoel's Avatar
Jasonnoel Jasonnoel is offline
Jasonnoel is gaining momentum as a positive member of FTE.Jasonnoel is gaining momentum as a positive member of FTE.
I have a 56 truck that I bought that has a 272 Y block in it bolted to a T10 4 speed side shift transmission. I've had a difficult time sorting out the right clutch kit and the throwout bearing is always wrong. Any suggestions?
Old 06-27-2014, 09:32 PM
Jasonnoel's Avatar
I'm also missing the speedo gear in the transmission. I'm not sure the tooth count.
Old 06-29-2014, 08:01 AM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
Need to know more like what style of presure plate, that makes a big difference in the T/O bearing.
Old 06-29-2014, 12:32 PM
Jasonnoel's Avatar
Quote:
Mine is similar to this style.
Old 06-29-2014, 12:35 PM
Jasonnoel's Avatar
Basically just need to know what that combo came in so I can order the right one up.
Old 06-29-2014, 09:13 PM
That is a picture of a Long style pressure plate and the Borg & Beck is "similar". Do you know what you have? Is it a Ford or GM T10? Are there any adapters in this set-up, modified components? God and the person who installed it are the only ones that know where the parts came from that cobed that trans into your vehicle. Pictures of everything including measurements of ID, OD, length of bearing, spline count and size of disc. Otherwise it is a shot in the dark and based on the response no else can provide the info unless you help us out.
If you chose not to provide the info here is a link to help maybe figure out what you need.
Accessories
Old 06-29-2014, 09:25 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
1961/64 Studebaker Lark & Hawk, 1963/64 Studebaker Avanti also used T-10's.
FoMoCo V8 T/O bearing is the same regardless of what M/T is installed.
The original bearing was separate from the hub, Ford later replaced it with a one piece assembly.
Old 06-29-2014, 09:51 PM
Jasonnoel's Avatar
Thanks for the info that has been provided. Let me do more digging and I'll report back what I find out. I'm thankful.
Old 06-29-2014, 11:23 PM
Jasonnoel's Avatar
Long style clutch pressure plate.
No adapters and nothing modified. Original bellhousing with casting numbers that came back as a truck with v8.
1.635-1.700" total length (roughly)
1.435 I.D.
3.00" O.D. (total outside)
2.63" O.D. (bearing face only)
1 1/16" 10-spline input shaft
11" disc
The throwout I have looks similar to the original we have been dealing with. Only difference is that the I.D. is way smaller. I understand what you are saying about the bearing being separate from the hub. The clutch we got the other day had a bearing that had to be pressed onto the hub.
Old 06-30-2014, 01:54 PM
If you look at the link I provide you will find you answer. You did not give the length of you T/O but based on your measurements there is only one choice. I will let you look at the link and compare for yourself. I led you to water now you need to drink.
Good luck.
Any reason why you can't make this change?? Hopsing69 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 12-17-2015 11:05 AM
clutch fork/throwout bearing? diesel85 Clutch, Transmission, Differential, Axle & Transfer Case 1 12-03-2015 11:01 AM
Transmission & Throwout Bearing Install Jmschneider 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-02-2015 10:11 AM
throwout bearing and slave cylinder HELP! patch2285 1987 - 1996 F150 & Larger F-Series Trucks 0 11-08-2014 01:22 PM
Replacing throwout bearing in a 4 cyl... staysbroken Ranger & B-Series 9 06-02-2014 07:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
