5.4 timing question - Ford Truck Enthusiasts Forums
5.4 timing question
Old 06-27-2014, 12:15 PM
Ja1980460 Ja1980460 is offline
Ja1980460 is starting off with a positive reputation.
5.4 timing question
I am about to start reassembling a 2003 5.4 2v that had a broken valve spring on the intake valve of cylinder number eight. This may be a stupid question, but since I only pulled off the drivers side head, do I have to retime the two cam shafts together, or can I just time the head I removed since the other wasn't messed with?
Old 07-07-2014, 04:09 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
no on timing the other bank that the timing chain was not removed from but everything must be in time if you did not move the other camshaft or crank or replace timing chain then as long as both cams are in time with the crank you should be good. just be sure to double check.
Old 07-15-2014, 10:10 PM
Modularation Modularation is offline
Modularation is starting off with a positive reputation.
All of the timing parts should be replaced.
2 valve 5.4 timing Mpollard1990 Modular V8 (4.6L, 5.4L) 1 11-23-2016 08:58 PM
99 F250 5.4 Rik Ping 1999 to 2016 Super Duty 0 04-02-2015 06:17 PM
5.4 long block kenny nunez Ford Truck Parts for Sale 0 03-24-2015 09:36 PM
Convert to 32 valve DOHC? Skauber Expedition & Navigator 3 03-02-2015 10:43 AM
5.4L 260hp/2 valve..How Long Before You Changed Your SparkPlugs? MWH615 1999 to 2016 Super Duty 27 03-02-2010 12:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
