Idea - eke a little more life out of front tires? - Ford Truck Enthusiasts Forums
Old 06-27-2014, 02:46 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
'95 F250 RCLB PSD ZF5 4x4 170,000-ish miles, TTB, 235/85R16 Cooper STs on generic look-alike Alcoas. The usual TTB effect on the front tires, aggravated by the fact that I did NOT rotate them when I should've. Cupping on the inboard tread blocks of BOTH front tires. Makes for a noisy crappy ride. But the tread's not bad.
Rear tires have more total tread, so I don't want to do a front/back rotation. Cross-rotating the front tires would still have the cupping on the inboard side tread blocks of each tire. So I'm thinking, to get some more miles out of the tires, I should have them dismounted and re-mounted (and balanced) the other way on the rim. This would move the cupping to the outboard side in each case, and the continued effect of the TTB would be on the other _side_ of each tire. Would it be worth it, if I could find some local tire jockey to remount/balance both for, say $20?
And no, I'm NOT in a position to swap in a solid axle. Too hard to come by here, and minimum $800-1000 just for the parts, not including all the replaceables (u-joints, tie rods, bearings, etc) you'd have to buy. We don't drive the truck enough to justify the cost (it took about five years for the tires to get to the state they're in).
Old 06-27-2014, 03:35 PM
RSpence75 RSpence75 is offline
RSpence75 is starting off with a positive reputation.
If you don't have them money for new tires now, I say do it. I have done many "Illogical" fixes due to money constraints, but if the money is available then definitely do it right. IMO
Old 06-27-2014, 08:04 PM
Crewcabber's Avatar
Crewcabber Crewcabber is offline
Crewcabber is gaining momentum as a positive member of FTE.
Give it a Shot and see if rides good and tracks straight.
Old 06-27-2014, 08:47 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
My question in all this is: How was it the TTB setup's fault?
My truck has 221,000 miles and it has NEVER worn the edges of my tires out.
I rotate them front to back, and have only had 1 alignment done since I've had the truck for 4 years.
Still no tread wear.
I recommend going to a GOOD alignment shop and having it gone over. Ball joints, camber alignment bushings, etc are all wear parts. All will need replaced at some point.
All can cause issues as you're describing.
Old 06-27-2014, 10:06 PM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
I second sidewinder, there is something amiss in your front suspension. A properly maintained and aligned TTB suspension should wear the tires perfectly even, just as any properly designed suspenion system should.
The "usual" TTB effect you are talking about is due to a bad alignment, worn components or both.
Old 06-28-2014, 10:21 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
If the inboard edge is feathered there's most likely a toe problem. If the inner edge is worn out (smooth) prematurely, it could be a camber problem caused by incorrect alignment or from sagging springs. A ride height measurement must be done first.
Old 06-28-2014, 10:35 PM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
You may be able to get Comstock Tire or Pomps Tire to shave the front tires to remove the cupping then have them take a close look at the ball joints and general condition of the front end components.
Having a competent front end shop do the work is imperative… you can pretty much forget about the national chain outfits. Any shop that does class 8 frame repair and alignment usually does light truck work, too. Those guys deal with I-beam axles everyday.
Old 06-28-2014, 11:44 PM
^^^^^ I was wondering about shaving the cupping off. Hmmm.
So do you know any good front end shop in SC WI? We've been going to a one-man operation off Fish Hatch called Accurate Alignment. Seems to know what he's doing. I have to admit, I don't even remember when I took that truck in last for an alignment.
Tire discussion Joshua Sirchuk Excursion - King of SUVs 8 01-15-2016 10:41 PM
front wheel shake, a fix that worked. andrewzx92000 1968-2013 Full Size Vans 4 11-29-2015 08:06 AM
Broke down and purchased 2 new front tires jonrjen 6.7L Power Stroke Diesel 9 11-10-2015 07:30 AM
Removing tire studs and how good is tire afterward? Fixnstuff Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 09-10-2015 01:16 AM
wierd front tire wear wildstang 1999 to 2016 Super Duty 11 04-13-2010 01:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
