Power Steering pump pully removal and install
This is the puller you need.
To reinstall the pulley, place the pulley on the shaft then take a flat washer, nut and bolt. Screw the nut on the bolt, place the flatwasher on the bolt and screw the bolt in the end of the shaft. Tighten the nut until the pulley's outside edge is flush with the end of the shaft.
Don't try using a gear or a 2 or 3 jaw puller. They won't work and all you'll do is bend the pulley.
octaneforce
01-24-2015 12:19 PM
blucollar4xford
04-23-2011 09:49 PM
pbuffing
09-24-2005 11:53 AM
