Got her Running good, but what the heck is this?
Okay so I got the ol Free F150 kicked over and running like a champ, but if you look in the image below I have something circled in red. I took this image for reference from another member, but need to know where this connected hose goes? My truck does not have this, and I've gone through my Haynes, but have no idea where to begin looking.
Well I started the gal up this morning to a sluggish idle that would fluctuate up and down until she finally would die out. Pulled the vacuum from the MAP and held my thumb over it to a smooth running truck. Switched out the map and she is back to running like a champ. My issue now is the Fuel gauge pegged beyond full. I have been trying to test the selector switch, but not sure I am doing it right. I read "Go to the switch and make sure there is voltage on the Yellow/White wire. When unplugged the gauge should peg full, and if the wire is grounded, the gauge should peg empty. If the gauge goes full unplugged, try jumpering across the plug to connector Yellow/White (Y/W) wire to each sensor wire. If the gauge reads normal, replace the selector switch. If not, follow each wire to the sender to see where they are shorted. Cut and run new wire as needed." somewhere, but not sure I understand the jumpering across plug part. Any help is appreciated.
Diesel 724
45
11-19-2010 07:40 AM
workingdog
18
02-22-2006 02:57 PM
mcanik
12-13-2003 09:02 PM
