1964 F100/M100 driveshaft configuration?
What did they use for drive shaft set ups? Mine is the 128" wheel base v8, 3speed manual. Looking under the truck it doesn't apear it was a 2 piece driveshaft with hanger bearing as I can't see any evidence of a hanger support mount etc. From tail shaft to the diff yoke is 67.5"
Also what did they use for a trans mount or cross member for the frame as mine doesn't have one of those either but you can see the tail housing is casted for a support mount.
1961/64 F100/700 is different: Bell housing (7505) has two ears. Two rubber insulators (6A061 lower & 6068 upper) used per side...as you can see in parts catalog pic.
Lower pic:
Flange made as part of extension housing: Trans mount bolts to flange then to cross member on Passenger Cars, 1965/66 F100/250 2WD, 1966 F100 4WD, 1967 and later F100/350.
Lower pic:
Lower pic:
thx
rio68
24
05-27-2018 07:14 PM
DDeffes
03-05-2015 08:57 PM
Scottybclarky
01-20-2015 05:42 PM
DasFord
02-20-2014 04:50 AM
portagoosey
01-12-2014 10:06 AM
