head swap - Ford Truck Enthusiasts Forums
head swap
Old 06-25-2014, 04:02 PM
tor_hag tor_hag is offline
tor_hag is starting off with a positive reputation.
head swap
Would anyone know if you could fit a diesel head on a gas engine?
Old 06-26-2014, 02:42 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.IDMooseMan has a great reputation on FTE.
Welcome to
I'm not sure why you'd want to do this, but here's my opinion. Diesel combustion cycles are handled differently than gasoline combustion cycles. You'd have to make so many changes to the diesel head, not counting any machining to mate it to the gasoline engine, that it would be cost-prohibitive, IMHO.
If you decide to attempt this swap, please post your process with a detailed write-up and lots of photos. I'd be very interested in the results.
Old 06-27-2014, 01:18 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
ONLY if they were the same engine family to begin with. That would leave you with an Olds diesel as the only one I could think of without research. There may be other farm equipment engines or maybe Mercedes Benz or BMW where the same basic engine was produced in gas and diesel.
I doubt you would find any such engine newer than 20-30 years.
In any event, you would not be able to just swap the head and have it run on diesel. Diesel requires much higher compression than the gas block would provide, depending on a number of things. And the cams are different. Plus, you need some kind of fuel injection system. And after all that, the gas motor internals are not up to the higher compression and cylinder pressures etc.
In short, you would be better to buy a diesel motor to start with.
Old 01-10-2015, 07:33 PM
dylansf23's Avatar
dylansf23 dylansf23 is offline
dylansf23 is gaining momentum as a positive member of FTE.
A 1.1 or 1.3 chevette diesel motor, was a gas Isuzu motor, they changed a few things and made it a diesel.
Old 04-08-2015, 10:54 PM
jimbbski jimbbski is offline
jimbbski is starting off with a positive reputation.
VW also converted a gaser into a diesel back in the late 70's.
Old 05-06-2015, 10:55 AM
TheDudeAbides's Avatar
TheDudeAbides TheDudeAbides is offline
TheDudeAbides is starting off with a positive reputation.
anything can be done...bottom line. it all depends on how deep your pockets are, and how much time you can spare. i'd start by getting some dimensions between the two blocks. determine bore spacing, bolt hole sizes/locations, water jacket ports, etc. many have used cleveland and LS6 heads for inlines, volvo heads for the 2.3L, the list goes on. there's a lot of homework and legwork to be done to take on something like this. gotta decide how much its really worth it to you and what your realistic goals are for the build.
400 build 79f1dy 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-13-2016 08:33 PM
Leaking head gasket murraycookies 6.0L Power Stroke Diesel 10 02-22-2016 08:02 PM
56 f600 Cummins head gasket rustyrelic 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 11-01-2015 05:46 PM
5.4 triton palynnsr 2004 - 2008 F150 13 10-19-2015 05:50 PM
another v10 oil leak Hoot_73 Modular V10 (6.8l) 4 09-29-2015 09:26 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
