2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
What do you want to see on the 2016 truck?
Old 12-04-2014, 02:30 PM
JRTJH's Avatar
JRTJH
JRTJH is offline
Trailering
A windshield washer/windshield pillar design that doesn't dump the bugs/fluid into the cab if the windows are slightly open. It seems "antiquated" to have to close the windows to clean the windshield.
  #152
Old 12-06-2014, 02:13 AM
Louisville Joe's Avatar
Louisville Joe
Louisville Joe is online now
Just noticed my 2013 F-250 company truck still has that foam sealer up in the rear quarter panels. It's up there between the inner fender and the outer quarter panel. I guess if they go aluminum this won't be an issue anymore.
  #153
Old 12-15-2014, 07:24 PM
King_Intense7's Avatar
King_Intense7
King_Intense7 is offline
I would like to see the 6.2 with direct injection and maybe even AFM like what GM has with their engines. As for the diesel, what they have for the 2015 is good enough. I like the style of the 2016. Don't know exactly what they look like but there are some pictures of them with camo covering them and they are looking pretty cool..
  #154
Old 12-16-2014, 10:37 PM
mowman98's Avatar
mowman98
mowman98 is offline
My 1999 the underneath was not painted at all rears both of them, drive shaft most of the front end parts
  #155
Old 12-25-2014, 12:15 AM
640 CI Aluminum FORD's Avatar
640 CI Aluminum FORD is offline
On the topic of the crush strength of the Superdutys roof.
Hopefully that will not be a problem in the 2016 SuperDutys since it appears that the cab design will essentially be the same as the 2015 F-150's.
The newer F-150's seem to handle rollovers quiet well, examples.
http://i.dailymail.co.uk/i/pix/2008/...19_468x286.jpg
http://i4.mirror.co.uk/incoming/arti...2246BB19F2.jpg
http://www.vnews.com/csp/mediapool/sites/dt.common.streams.StreamServer.cls?STREAMOID=Cilb9 rHXWhpB8RmGwVR50c$daE2N3K4ZzOUsqbU5sYsEmRc_NdF1yJh urk4ZABgnWCsjLu883Ygn4B49Lvm9bPe2QeMKQdVeZmXF$9l$4 uCZ8QDXhaHEp3rvzXRJFdy0KqPHLoMevcTLo3h8xh70Y6N_U_C ryOsw6FTOdKL_jpQ-&CONTENTTYPE=image/jpeg
http://i.kinja-img.com/gawker-media/...iq6cwc5jpg.jpg
https://www.google.com/search?q=F-15...er%3B320%3B260
With all of that said, the thing I would like to see most in the new Superdutys is a true PowerWagon competitor, and I would also like to see Ford offer a decent mid range gas engine...Something like a 6.5L or 7.0L V8, hell they could market a 7.0L V8 as a modern day Cobra Jet. But at the very least I would like to see the 6.2L get a power bump, perhaps through the addition of direct injection.
It's also been suggested that Ford should do a retro truck...I would be in some financial trouble if Ford did a 1973 - 1979 retro Superduty, because I would literally be scraping change to get my hands on one of those with a big gas V8.
  #156
Old 12-25-2014, 01:26 AM
mario1987's Avatar
mario1987
mario1987 is offline
how about a straight shift again and a stiff frame
  #157
Old 12-25-2014, 10:18 AM
the_croz's Avatar
the_croz
the_croz is offline
What I'd like to see on 2016 450-550 Super Duty Chassis Cabs
I'd like to see Dual Tanks offered on options above XL & XLT.
I'd like to see the Pick-up 440 Hp, 880 Lb. Ft. Torque power plant available in the Chassis Cab.
I'd like to see the Turbo Brake offered on the Chassis Cabs.
I'd like to see the 80 MPH limiter removed from the Chassis Cab.
I'd like to see better (stronger) material use on the Frames to prevent the bobble head syndrome.
I'd like to see the Back-up Camera available on Chassis Cabs so we won't have to spend another $600.00 for an after market integration Module to hook one up.
I'd like to see the DVD player capability returned to the CD player.
I'd like to see the DEF system go away completely.
  #158
Old 12-27-2014, 06:20 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
My wish list
4 captain chairs (back seats same as front)
Cruise control like already discussed. I want to be able to have a screen where I can select my speed similar to tuning to a radio station. Set speed to a specific value. Like "72mph", etc...
Factory air suspension with manual control (ride height and leveling)
More than 4 aux switches (up fitter)
Factory pto options like air or generator
  #159
Old 12-29-2014, 05:16 PM
T diesel's Avatar
T diesel
T diesel is offline
Okay, how about a cabin filter..... https://www.youtube.com/watch?v=XyaMZXYADyc
  #160
Old 12-29-2014, 10:22 PM
rollerstud98's Avatar
rollerstud98
rollerstud98 is offline
Some more spy shots amd info
  #161
Old 12-30-2014, 08:00 PM
Y2KW57's Avatar
Y2KW57
Y2KW57 is online now
Received 3,327 Likes on 1,744 Posts
I want the basics...what they taught us growing up in school. The three R's.
Reliability. Room. And most of all, I just want it to Run. No more of this Found On the side of the Road stuff any more please. Just basics.
If you want to add options, then consider putting in some Rear wheel horsepower and Real world capabilities... and give all those Rating games you play a Rest.
And finally, it wouldn't hurt to have a bigger Rebate.
  #162
Old 01-03-2015, 03:05 AM
hoaka's Avatar
hoaka
hoaka is offline
4wd Low
LED headlights, softer plastics on dash/door/console, different "wood" choices on high trimlines, an STX or Sport line, blind spot monitoring, different leather for the King Ranch steering wheels that don't "age" as fast.
  #163
Old 01-07-2015, 09:34 AM
erikf's Avatar
erikf
erikf is offline
Larger fuel tank. I was shocked when I filled up my 2015 and it only has a 26 gallon tank.
  #164
Old 01-07-2015, 10:04 AM
the_croz's Avatar
the_croz
the_croz is offline
You must have the Mid-ship tank. Bummer.. I had to order a second Truck because when the dealer selected the mid-ship tank thinking he was adding it didn't realize he also deleted the 40 gallon Aft tank. You can't get dual tanks on anything above an XLT.
  #165
Old 01-07-2015, 06:43 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
Didnt know you could get dual tanks on any of them. Nice. I am pretty happy with my single 37gal though.
Quick Reply: What do you want to see on the 2016 truck?
