Ring Gear Size - Ford Truck Enthusiasts Forums
Ring Gear Size
Old 06-25-2014, 11:57 AM
bluecobra bluecobra is offline
bluecobra is starting off with a positive reputation.
Ring Gear Size
I have an 2001 F-150-5.4-4wd-H-9 diff.
Looking on RA to buy rear axle bearings. How can I tell if the ring gear is 8.8 or 9.75. I have seen posts that said if the diff cover has 10 nuts its 8.8 but if it has 12 its the 9.97. I know there's a tag on the diff with codes, I'm hoping there's an easier way to tell than having to climb under the truck.
Any and all help is appreciated.
Old 06-25-2014, 05:12 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
Get under and look.
Suppose your told wrong?
The truck had several options for size depending on model and build.
H9 is the ratio and open or limited slip ID.
Good luck.
Old 06-25-2014, 07:00 PM
Thanks Bluegrass,
I did get under and its a 9.75 RG.
Old 06-25-2014, 09:55 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
this is the smaller 8.8 inch - note cover circle
Old 06-25-2014, 09:56 PM
steve(ill)'s Avatar
9.75 is more egg shaped
Old 06-29-2014, 11:21 PM
STOFFERJ STOFFERJ is offline
STOFFERJ is starting off with a positive reputation.
all 5.4 equipped F-150's had 9.75's from the factory
Old 07-01-2014, 04:50 PM
Got bearings & seal for the 9.75. Pulled the old ones and discovered the the 9.75
bearings were too big. It took the 8.8 bearings instead. Go figure!
Dana 44 Catastrophic Failure rat_6 Clutch, Transmission, Differential, Axle & Transfer Case 10 02-03-2016 04:55 PM
What is it worth, should I buy? 96 Ranger Frank Murch Ranger & B-Series 5 12-25-2015 07:47 PM
Ford 8.8 woes dober83 Clutch, Transmission, Differential, Axle & Transfer Case 9 09-25-2015 06:42 PM
Rear diff ring gear sean9049 1994.5 - 1997 7.3L Power Stroke Diesel 6 10-08-2014 05:19 PM
Ford 9" carrier dimensions - for 9 3/8" diff center Ford938 Clutch, Transmission, Differential, Axle & Transfer Case 2 12-29-2013 09:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
