F150 supercab door stuck
Hey guys new user here liking the forum so far . Anyways ive had a problem with my ,2001 F150 Supercab, one of my back doors on the driver side for a few months now is stuck. The door refuses to open ,when the handle is pulled the door pops, as if it is opening but the top part appears to be jammed or not releasing. I have come to the conclusion that it is a problem with a rubber piece in the mechanism that has worn over time.
I was wondering if any of y'all had any problems like this? If so what do you recommend I do to fix this. Thanks for any help
Is it both handles or just one? I had an issue where the rod for the inside handle came detached from the latch, but it fell down on to the magnet of speaker and i would pop when you pulled the handle from where is got stuck. The outside(covered by the front door) handle still worked fine.
Sous
09-18-2016 11:00 AM
BocceMon
16
05-23-2014 04:09 PM
