1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Gear swap question/tire question
Old 06-28-2014, 07:29 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
I have 4.88s with 9.75 diff on my 150 4.6 with 35s on 9inch lift and what a difference in acceleration. Down side is the lack of fuel mileage. Went this route to make this truck better for towing.
My 250 I had it ordered with 4.30 knowing a 6inch lift and larger tires were being installed. Have 37s on now and truck drives well. 40x15.5 are going on shortly with these 37s going on 150. Cant wait to see how the 4.30 handles these larger tires.
Old 06-28-2014, 07:57 AM
zimm's Avatar
zimm
zimm is offline
Nope. You need the install kit too. Bearings a good idea. Have you ever set up a ring and pinion? Takes special tools, micrometer, marking compound to check mesh pattern, etc. it's not a bolt in affair. Plus I'm pretty sure you need new carriers to go above 3.73. Call Randy's and find out for sure. I would but parts from autozone, use Randy's because they're experts and will get you the stuff you need. Also see if you need a tone ring for the ABS for your year.
I would have a shop do it though. If it's installed wrong you'll get gear whine or wreck your gear set and you wasted all that time and money.
Diff Wizard
Splatts
25
12-03-2013 02:27 PM
Randallman
Modular V10 (6.8l)
04-10-2013 07:36 PM
turdfire
Offroad & 4x4
12-14-2006 08:50 AM
boxcar1974
Modular V10 (6.8l)
03-20-2006 07:00 PM
jbrowning
08-10-2003 06:44 PM
Quick Reply: Gear swap question/tire question
