80 Econoline 351 5.8l engine overheating - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 06-25-2014, 08:36 AM
Aimableht's Avatar
Aimableht Aimableht is offline
Aimableht is starting off with a positive reputation.
Yesterday, I did basic service, changed oil and oil filter, spark plugs, spark plugs cables, fuel filter, thermostat and its gasket.
Afterward when I was driving I notice that my engine was overheating, what can be the problem?
Old 06-25-2014, 09:32 AM
econolinemanor econolinemanor is offline
econolinemanor is starting off with a positive reputation.
Could be an air pocket trapped after changing the Thermostat........
Old 06-25-2014, 09:37 AM
Aimableht's Avatar
Where is air pocket on that engine, a picture or diagram will be helpful.. I am still familiarizing that engine. Thanks
Old 06-25-2014, 11:36 AM
It's more of a procedure for bleeding off any trapped air, check YouTube and Google it. It can be very dangerous if you have never done it before, 195 deg coolant can take your skin off instantly............But since you have already driven it I would just recheck the Coolant level (cold) and see if it has dropped any and refill as necessary, it might settle out on it's own....maybe.
Old 06-25-2014, 11:40 AM
jack orchard jack orchard is offline
jack orchard is starting off with a positive reputation.
bleed out air
if it doesn't bleed of by itself, find the highest point of cooling system (temp sensor, etc). open system at that point, bleed air out until only coolant comes out. Good luck.,,,,jack
Old 06-25-2014, 11:49 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Great advice on the hot coolant---its actually much hotter than indicated since its under pressure---my guess is it approaches 245* or more.
I've always bled off the cooling system by first filling the radiator & block as much as possible. Start the engine, the level should drop as the water pump pushes coolant through the block. Refill coolant while engine is still running, replace radiator cap, sit inside the van and watch as the temp gauge rises. Now's a good time to turn the heater to High, blower motor also on High---warm air through the vents says coolant is at least circulating through the heater core.
The temp should climb slightly above normal operating temp then drop quite a bit---thermostat has opened and coolant is flowing---CAREFULLY and SLOWLY turn the radiator cap just enough to vent built up pressure. Once the radiator is under atmospheric pressure time to add more coolant, up to the recommended level in the radiator.
IF the level seems full raise the RPM's to at least 1500-1700 (helper) while watching the radiator level. Any trapped air will be pushed out because the water pump is working better, the level will drop slightly if air was present.
Raise and lower the RPM's several times during this step to make sure no more air is trapped in the block. Once the coolant level remains constant replace and secure radiator cap.
That should work for any of the older engines---always has for me.
HTH
Old 07-05-2014, 07:00 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
You haven't put the new thermostat in backwards?
92 302 overheating eenyok 1987 - 1996 F150 & Larger F-Series Trucks 3 12-28-2016 10:45 AM
Starting issues Mike Jahnke 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 11-13-2015 08:21 PM
2004 f250 5.4 overheating fixed shanerus Modular V8 (4.6L, 5.4L) 0 11-10-2015 11:26 AM
1990 Bronco Overheating Baws 1978 - 1996 Big Bronco 10 08-09-2015 11:44 PM
2004? V-6 Explorer water in exhaust nairod Explorer, Sport Trac, Mountaineer & Aviator 8 10-04-2014 02:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
