I talked to mid early ford about some tail lights brackets, seems like I don't have a stock tail gate, my bolts are about 3 inch apart and the brackets are about 2inch
Thanks
Hard to tell on the tailgate, but I'd guess its a stock gate with some round bar pounded into the lower part of the tailgate and hung with some home brewed hinges.
I agree, it looks home made to me. I bet if you remove that backing plate on the backside of the stake pockets you will find the properly spaced holes.
So what does this mean, , is it a 53 tail gate, , i tried to get the right bracket, and they didnt know what i had, ,,i did order the long stright ones, not the bent ones but the holes do not line up
It looks like you could modify the brackets by cutting the holes vertically into slots. loosen bottom hinge bolt, and remove the top on, slip the bracket in over the bottom bolt and center it between the bolts. replace top bolt and tighten both to lock the bracket in place.
kinda what i did , after i got the right brackets ths ones i needed was 3/4 longer and straight not bent ,, all is good for now got 1 side done , i had to enlong the bolt holes in the bumper brackets also to side the bumper over about a 3/4 inch ,,
thanks
