91 gas F350 wire shorted - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 06-25-2014, 01:52 AM
manram manram is offline
manram is starting off with a positive reputation.
I'm helping a friend fix his truck. He has a short to ground in the big gauge (not the smaller yellow ones) yellow wire that is not on the fuse link off the starter relay. It goes from the relay to somewhere..I traced it all the way to the big round connector going though the firewall but can't see where it goes from there. I don't think it goes to the fuse box. Anyone have a schematic that tells where this wire connects. It is shorted to ground and the battery doesn't like that! thanks.
Old 06-25-2014, 04:15 PM
rvpuller's Avatar
rvpuller rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
If it's a 91 you should be posting your question in the 1987-1996 F150 & larger F seried trucks forum, the 6.2 is only in 2011 and newer trucks.
You can repost it or I will move it for you.
Welcome to FTE
Denny
Old 06-26-2014, 12:37 AM
yeh, noticed that after I posted. Reposted in the right forum-88 views, no replies.
Don't get it!
Old 06-26-2014, 07:43 AM
rvpuller's Avatar
It could be that the right person that's had the same problem hasn't seen it yet. I had two of them in that same vintage and never had a problem in that area so I'm no help.
Denny
95 F150 Grounding Issue SRich77 1987 - 1996 F150 & Larger F-Series Trucks 3 10-10-2016 09:19 PM
central junction box Gmcbuffalo Excursion - King of SUVs 4 04-24-2016 03:21 PM
FP relay not grouding through Pin 22 A.j. Smith 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 10-29-2015 04:45 PM
PCM/IDM expert advice needed - BADLY!!! OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 35 12-13-2014 06:24 PM
91 Gas F350 wiring short manram 1987 - 1996 F150 & Larger F-Series Trucks 13 06-30-2014 10:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
