late 90's exploder 8.8 disk brake rear possible swap?
Old 06-25-2014, 12:26 AM
Trey_Morgan's Avatar
Trey_Morgan
Trey_Morgan is offline
Hey guys, I have a friend with a 1998 or 1999 explorer 8.8 rear axle that's complete from the leaf springs to the lug nuts and he wants it gone. So I can pick it up for super cheap. Now my question is: I've seen dropss write up on the Dakota spring swap I was just wondering if anyone has used the explorer axle springs and all? I know the axle width is perfect and the disk brakes will match my ifs disks in the front. Just hoping someone has some experience with the explorer axle in particular.
Old 06-25-2014, 05:18 AM
topmoo's Avatar
topmoo
topmoo is offline
I put a 2000 Explorer rear in mine but didn't use the springs. I used new CPP springs made for F1's with an all new mount system supplied with them. I had to buy perches at an off road Jeep parts supplier for the 3 1/4" Explorer axle tubes. The brakes work great and it is set up with an emergency brake that is pretty easy to adapt.
Old 06-25-2014, 10:42 AM
big schott's Avatar
big schott
big schott is offline
Old 06-25-2014, 06:19 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Trey,
We've got the Full Explorer rear end (2001 edition) under our '50. I was a little worried about using the 3 rear spring set when I took off the stock 8? original spring set up but we've used it for hauling couches, etc. It works fine.
Is the ride as smooth as my late model cars? No. It's a truck - It's smooth at highway speed a bit bumpy around town over potholes etc.
Ben in Austin
1950 F1
Old 06-27-2014, 08:39 AM
jbontke's Avatar
jbontke
jbontke is offline
Originally Posted by big schott
I have the 2001 Explorer axel. I had to remove the perches and mount new ones on top side. I just used the original springs and did a little modification to make it all work.
What did you use for the spring perches? Something from a fab shop or parts from the explorer frame?
Old 06-30-2014, 01:37 PM
big schott's Avatar
big schott
Just a set for 3.25" axel off e-bay.
<a href="http://s361.photobucket.com...692.jpg"/></a>
Old 06-30-2014, 02:27 PM
jbontke's Avatar
jbontke
jbontke is offline
Sorry, I thought you used the explorer leaf springs and was wondering what hanger setup you had.
quadeyenny
05-11-2019 01:05 AM
ETOWN55
35
01-24-2015 07:14 AM
mstng5point0
16
01-02-2012 10:10 PM
CobraDan
11-11-2006 12:47 PM
jv982
1983 - 2012 Ranger & B-Series
03-10-2005 09:21 PM
Quick Reply: late 90's exploder 8.8 disk brake rear possible swap?
