late 90's exploder 8.8 disk brake rear possible swap? - Ford Truck Enthusiasts Forums
Old 06-25-2014, 01:26 AM
Trey_Morgan's Avatar
Trey_Morgan Trey_Morgan is offline
Trey_Morgan is starting off with a positive reputation.
Hey guys, I have a friend with a 1998 or 1999 explorer 8.8 rear axle that's complete from the leaf springs to the lug nuts and he wants it gone. So I can pick it up for super cheap. Now my question is: I've seen dropss write up on the Dakota spring swap I was just wondering if anyone has used the explorer axle springs and all? I know the axle width is perfect and the disk brakes will match my ifs disks in the front. Just hoping someone has some experience with the explorer axle in particular.
Old 06-25-2014, 06:18 AM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
I put a 2000 Explorer rear in mine but didn't use the springs. I used new CPP springs made for F1's with an all new mount system supplied with them. I had to buy perches at an off road Jeep parts supplier for the 3 1/4" Explorer axle tubes. The brakes work great and it is set up with an emergency brake that is pretty easy to adapt.
Old 06-25-2014, 07:19 PM
ben73058's Avatar
ben73058 ben73058 is offline
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey Trey,
We've got the Full Explorer rear end (2001 edition) under our '50. I was a little worried about using the 3 rear spring set when I took off the stock 8? original spring set up but we've used it for hauling couches, etc. It works fine.
Is the ride as smooth as my late model cars? No. It's a truck - It's smooth at highway speed a bit bumpy around town over potholes etc.
Ben in Austin
1950 F1
Old 06-27-2014, 09:39 AM
jbontke's Avatar
jbontke jbontke is offline
jbontke is starting off with a positive reputation.
Quote:
Originally Posted by big schott View Post
I have the 2001 Explorer axel. I had to remove the perches and mount new ones on top side. I just used the original springs and did a little modification to make it all work.
What did you use for the spring perches? Something from a fab shop or parts from the explorer frame?
Old 06-30-2014, 02:37 PM
big schott's Avatar
big schott big schott is offline
big schott is starting off with a positive reputation.
Just a set for 3.25" axel off e-bay.
<a href="http://s361.photobucket.com...692.jpg"/></a>
Old 06-30-2014, 03:27 PM
jbontke's Avatar
Sorry, I thought you used the explorer leaf springs and was wondering what hanger setup you had.
Explorer axle swap project started. Pablo-UA Ranger & B-Series 6 12-29-2014 06:09 PM
98 Explorer Axle Swap into 93 Lightning Roadbird Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 2 11-05-2014 09:29 PM
Rear disk swap UNTAMND 1987 - 1996 F150 & Larger F-Series Trucks 58 01-17-2012 12:11 AM
Emergency brake setup for 8.8 Rear rzns60 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-03-2011 05:33 PM
Boneyard disk brake convertion. Help finding. crazedfox 1973 - 1979 F-100 & Larger F-Series Trucks 15 05-02-2009 10:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
