2001 F250 Heater Blender Door Actuator - Ford Truck Enthusiasts Forums
Australia Chapter Join Chapter , Leader: ChunderDownUnder
Old 06-24-2014, 11:25 PM
Apocalyps's Avatar
Apocalyps Apocalyps is offline
Apocalyps is starting off with a positive reputation.
Hey there Guys,
I am new to this site, so g'day.
I have a 2001 F250, and the heater blender door actuator/mechanism needs swapping out. I have seen how it's done, with access via removing the glove box inner.
My problem is that I have an Aussie Compliance model, RHD with no glove box.
Any idea how I can access the actuator? Will I need to remove all the plastic dash etc, if so, how do I go about this?
Cheers Guys.
Old 06-25-2014, 08:48 AM
Aussie BrianB's Avatar
Aussie BrianB Aussie BrianB is offline
Aussie BrianB has a good reputation on FTE.Aussie BrianB has a good reputation on FTE.
G'day, welcome to the forum mate.
Sorry but I can't help with your problem, I have a glovebox free
dash as well.
I am pretty confident someone on here will have an answer
for you though.
Old 06-25-2014, 04:33 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
yep. thats a tuff one. I doubt anyone here has tackled that problem and the boys in the States wont be any help. My guess is that the dash has to come off. I would ask the people that do the conversions.
Old 06-27-2014, 02:32 AM
aussie_f350's Avatar
aussie_f350 aussie_f350 is offline
aussie_f350 has a good reputation on FTE.aussie_f350 has a good reputation on FTE.
We did mine, ***** of job all dash has to come out to get heater box out. 8 hrs work and a $15 part.
Old 12-20-2014, 12:48 AM
Fraree's Avatar
Fraree Fraree is offline
Fraree is starting off with a positive reputation.
Thumbs down
Quote:
Had similar issues with air doing its own recirculation trip around under the dash.
Let the vent system go to default during the winter up at Guyra for some defogging action but now its summer, the need for the A/c to blow out the face vents is a priority Just a B'std of a job.
Old 12-20-2014, 05:15 AM
Fraree's Avatar
Wink
Another issue with air direction within the system I've found is the foam between the plastic parts has disintegrated over the life of the vehicle, leading to "air leaks" in the direction of ventilation. The blend door was another leakage. Replacing the foam, has eliminated that part of the leaks but there's more to be located yet.
Cabin "cooling" is the main issue down here, as we don't suffer from the endless "bollocking" cold winters you blokes endure in the northern hemisphere.
Its a pity there isn't ability to direct more outside venting at your feet in these trucks, so WD@60 (Window down @ 60mph) air conditioning is about the best one can do.
94 f250 blend doors Psykoemaniac 1987 - 1996 F150 & Larger F-Series Trucks 17 12-16-2016 01:10 PM
Heater Blend Door on 1989 F250 Boris Levit 1987 - 1996 F150 & Larger F-Series Trucks 5 06-27-2016 09:14 PM
No heat...blower runs fine...help! AikenRooster 6.0L Power Stroke Diesel 4 09-23-2015 02:04 PM
2001 F250 Heater Blender Door Actuator Apocalyps 1999 to 2016 Super Duty 0 06-24-2014 11:23 PM
Help wanted, 2008 f250 heater won't switch cabbie 1999 to 2016 Super Duty 3 05-23-2012 06:25 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
