Anyone recommend a good repair manual?
They might be expensive(unless you find a used set on ebay), but I would say the 1987 Ford light truck shop manuals are the best. I went ahead and bought a new set for my 1990 Bronco last year, and they've helped me out a lot better than the others I've bought. You might also try picking up a set of 1987 Ford Light Truck Specifications Books. I found a good condition set for the 1990 model year,on ebay, about a year ago. You might try helminc.com to see if they have them in stock, or search on ebay. Hope this helps.
If you haven't purchased one yet, run down to your library, check them all out and see which one is right for you and your vehicle. I did it and liked the fact that if one doesn't cover what I need, I'll find on that does. I don't spend any money, unless I make copies.
