Newb with a 97 F250 - Ford Truck Enthusiasts Forums
Newb with a 97 F250
Old 06-24-2014, 07:43 PM
mechmagcn's Avatar
mechmagcn mechmagcn is offline
Diesel Junky
mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.mechmagcn has a very good reputation on FTE.
Newb with a 97 F250
Hi Guys, have owned and worked on diesels for years but new to Powerstrokes. Have tried my hand a time or two in the past and got frustrated and gave up. Well....I bought a 97 F250 4X4 PSD auto a few weeks ago. The truck has been sitting about 18 months but started easily with new batteries.
During initial inspection I noticed the engine surging and idling very rough. It also has a loud cackle, maybe one bad injector. If I unplug the ICP it will level out and idle well. I installed some gauges on the hipop rail and fuel schrader valve. Hipop was up and down from 1K to 1.5K with ICP plugged in and 1.5K steady unplugged. Fuel pressure is around 45 PSI.
Driveability is hampered by the fact that the shift **** is broken and the OD wires are just hanging there, does anyone know if the shift lever from a 94 F250 w/o tilt will fit a 97 w/tilt?
Ordered an Auto Enginuity scanner today since I need it to diagnose my truck and have a customer that has 2 Powerstrokes that need some attention.
I've been a regular on the older truck forums and the IDI diesel for years, guess you folks have another newbie to break in for this forum.
Old 06-24-2014, 09:11 PM
Fordownsall's Avatar
Fordownsall Fordownsall is offline
Fordownsall is starting off with a positive reputation.
sitting for 18 months, i'm sure you know this if your a diesel junkie but i would definitely change fuel and oil filters, and run some fresh fuel and oil through that bad boy, and start from there
Old 06-24-2014, 09:27 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Welcome Jeff! With the idle leveling out when you unplugged the ICP, and the fluctuation in the high pressure oil, you could have a bad ICP or sticky IPR. Was there any oil in the ICP plug? Oil level and condition could play a role also. Check the UVCHs and pigtails for burnt pins too.
Old 06-24-2014, 09:50 PM
mechmagcn's Avatar
Diesel Junky
Surprisingly the oil is as clean as if it was changed just before being parked. Fuel filter is new. Condition of pigtails and gaskets is unknown so far. There was no oil in the ICP, so I hope it is good. Plan to pull the IPR next and clean it. Really waiting for the AE to get here before I buy anything, not one to throw parts at a problem and hope it goes away.
Old 06-25-2014, 09:33 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
I'd still Change the oil and replace the fuel filter. The oil quality is very crucial for injectors
Old 06-25-2014, 12:34 PM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
What he said...^^^
Old 06-25-2014, 01:49 PM
mechmagcn's Avatar
Diesel Junky
Quote:
Will do! Now as to not start an oil brand discussion, just run a quality 15W40 oil?
And how many qts. to fill?
I'm a professional diesel mechanic by trade, just mostly have worked on older mechanical equipment. Have owned many mechanical diesels, currently have 2 F250 IDIs, one Dodge/Cummins and the 53 F100 with a Mercedes diesel for power.
Looking forward to learning a little about the Powerstrokes.
Old 06-25-2014, 02:24 PM
Rotella 15w-40 is usually what most go with and seems to work well with the PSDs, but any 15w-40 Diesel rated oil will be fine.
Old 06-25-2014, 04:39 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I ran rotella for a long time, good oil. But basically like Byron said, a good quality diesel rated oil will be fine. Takes about 15 quarts.
Old 06-25-2014, 04:52 PM
mechmagcn's Avatar
Diesel Junky
Quote:
Seems most of my customers are split 50/50 on Rotella and Delo.
I have run Delo in everything for over 25 years with no problems.
Old 06-25-2014, 04:55 PM
Either or I say. My buddy runs delo in his 03, ran it in all the strokes he's had. I now run shaeffers.
Old 06-25-2014, 05:53 PM
mechmagcn's Avatar
Diesel Junky
I have one customer running Shaefers, I love their synthetic grease, but haven't had enough experience with the motor oil to make an informed decision yet.
Old 06-25-2014, 11:58 PM
Leatherneck007's Avatar
Leatherneck007 Leatherneck007 is offline
Leatherneck007 is starting off with a positive reputation.
i prefer mobil 1 full synthetic. used to run schaffers 50/50 blend in my gassers till iheard that at the bottom of every barrel is little black sand sized beads. scared me away from it. mobil 1 is awesome.
Old 06-26-2014, 05:27 AM
Quote:
And where in the world did you hear that? If you sold motor oil with sand in it, you'd not be in business too long..
Old 06-26-2014, 07:55 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^^^ Has the sound of an urban legend.
5.4 oil leak and wake up iowa rbig1 Iowa Chapter 1 05-27-2016 10:28 AM
Noob Intro: 84 F250 (VA) gluefactory New Member Introductions 0 09-17-2015 02:57 PM
My First Post Arizona97 New Member Introductions 2 04-09-2015 03:06 PM
Want to buy Wheels Major Marvin 1994.5 - 1997 7.3L Power Stroke Diesel 12 10-15-2010 03:07 PM
New Member Here Just Sayin High SUCKMEUP 1999 - 2003 7.3L Power Stroke Diesel 34 10-24-2007 12:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
