best head gasket for 429 with 10.5 C.R - Ford Truck Enthusiasts Forums
Old 06-24-2014, 08:21 PM
gumshoe gumshoe is offline
gumshoe is starting off with a positive reputation.
I'v read thru this forum for info on the best type or brand of head gasket to use on a 68 T-Bird 429 engine that I am near ready to install the heads whitch have 10.5 or 11.0 c.r. Nothing found on head gaskets. I am leaning towards the ford racing set as it has the steel ring around each cylinder. about $75. from summit. anyone have experance with this? thanks.
Old 06-29-2014, 11:51 AM
krooser's Avatar
krooser krooser is offline
krooser is gaining momentum as a positive member of FTE.
Fel-Pro blue...
C.R. with 58cc chambers ? gman97005 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 01-23-2016 12:55 PM
429 build help dying breed racing Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 05-01-2015 09:25 AM
10.5 - 1 compression goal 1978Crew 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 13 10-17-2010 08:30 AM
TRW pistons good enough? dogsniper FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 04-24-2007 12:06 PM
SCJ piston question tess100 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 02-06-2004 05:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
